Can anyone explain how to create a momentary switch behavior using Insteon? Where if the user is physically holding down a button then the lamp is lit, conversely, when the user lets go, the lamp goes out. The lamp should never light unless the button is held down, conversely, the lamp should never go out while the button is being held down. IOW the lamp is normally off and only on while someone is holding the button down. Is this possible using any of the standard Insteon products?
- posted
16 years ago
