I have a 600w magnetic 120V - 12V transformer that has 2 - 300 W 12V circuits that I plan to use for lighting. I would like to control the
2 load 12V sides independently. Is there a comercial dimmer (X-10 or eqivalent) that will control the LV load side? If not a dimmer, is there a remote switch that will do it?
What's your application? One of the biggest advantages of low voltage is that you can use DC power from batteries. Is that your intention? If so, TRIAC-based dimmers like those used in most conventional dimmers won't work. Like the X-10 signal itself, they need AC.
Or are you using low voltage for safety or other reasons?
Or a new-fashioned fixtures and lamps with (eg) exposed conductors that have become fashionable. I think they'll be neato at least for a while ;-)
If it's just because you have the transformer, you might reconsider.
In the US, the National Electrical Code (NEC) allows for 'interesting' configuration of low-voltage ( =
