all
informative
transmission
I decided I wasn't as concerned about the Monterey's lack of max voltage indication as I was that the ESM-1 and the Monterey agreed. In fact, it was you message about how the ESM-1 was calibrated at the factory to agree with the Monterey that made finally decide to buy one. That turns out to be a plus for me since one meter can serve as a sanity check for the other in the face of bizarre readings. As far as profiling the transmitters that overwhelm the Monterey, I can read them through a filter I'll keep offline as a "reference attenuator" that shifts the signal into the range the Monterey and ESM-1 are set to measure. Not ideal, and certainly not useful to compare my readings to anyone else's, but it shouldn't affect my goal of having baseline numbers for every device. I wonder if the Monterey has a similar potentiometer to the ESM-1 for adjusting the scale?
This has got to be the most heavily researched thing I ever bought! )-: I've read lots of previous threads about the unit, particularly between you and John Gavin (sp?) where you discussed decay rates of the CM11A signal and methods of measuring the signal quality (where on the AC cycle samples are taken, how many, etc.). I struggled mightily with the Monterey over the ACT that Bruce R. likes and decided as long as neither has an output port, the smaller size of the Monterey makes it worth the premium.
While an oscilloscope would be the best way to look at an X-10 signal, on a practical level, I need something I can tote to the places I have having problems. I forsee getting the USB scope you cited a while back, but right now I need real world tools that help me diagnose the few intermittent problems that still plague me.
As for a test bench, it's going to be hard to keep it isolated from other X-10 transmitters, which I learned through you and Google all attenuate (is that the right word in this context?) the X-10 signal slightly. I've got
*lots* maxis and minis deployed house-wide.I thought about plugging the test strips into two 100' 14AWG extension cords I have just to put some distance between the test bench and the rest of the house, but your suggestion of measuring with and without a filter will probably tell me (with the Monterey or a scope, at least) whether there's a signal sucker on that circuit leg. If the measurements are too far out of synch, I might go back to the 200' of cord idea.
Probably the best way to test would be to shut down all breakers in the house except for the one I was using to test, but the last time I did that, I got into BIG trouble for blowing up the VCR's programming. (Actually, I did it twice. When I reset the programming, I inadvertently set the time for AM instead of PM. Oddly enough, the unit seemed to be coming on at the right times, but in reality, they were out of phase by 12 hours).
Since the great breaker box fiasco, SWMBO has put a limit on the number and type of "research projects" I can engage in at any one time. I have to apply for permission to shut off the panel since I mucked up the recording of a "Series Finale." The currently approved project is to get the HAI Omni LT function as a basic alarm system, capable of calling a series of numbers when an alarm event occurs. I have one week, starting tomorrow, to get it done! (So, why am I here in CHA, you ask?)
Wasn't someone in CHA measuring their home's impedance at the breaker box?
I saw an article that talked a bit about powerline impedance here:
Protocol to Avoid Noise in Power Line Networks engrwww.usask.ca/research/ ee/faculty/ded632/files/Powerline2005.pdf
And there's an enormous powerline FAQ at:
Thanks again for you insight, Dave. I'll be sure to post when "Monty" arrives. My main purpose in buying it is to get very accurate readings of the X-10 signal strength at multiple points throughout the house. There are just too many "semi signal suckers" that seem to cause a degradation of the signal, but it's just too small a voltage for the ESM-1 to see it (and I've tried videotaping the display and playing it back in slow motion to see if I could see a difference in the # of bars lit per frame). That's when I decided that despite its shortcomings, the Monterey is going to give me the degree of precision I need as admirably as it's going to unfill my wallet. :-( It really is just a little too expensive to make me feel really comfortable with it, but my vendor assures me they'll take it back if I don't like it. We'll soon see!
-- Bobby G.
