Hi! I'm very new to X-10 and just bought a starter kit to control a flourescent light I have because the ads said it would work on an appliance module.....it doesn't.
I'm trying to get a AM466 to run a flourescent light. I've done the modification to turn-off local control by cutting the trace which helps it stay in the so-called off position, but the module still supplies a small amount of voltage out which causes the light to pulse (blink) in the off position. I'm not sure if there is a mod, or it's not clear to me, that would actually make the AM466 be totally off when in the off position.
The light in question is a 13W flourescent performance light from Home Depot.
Any help identifying what I need to do would be greately appreciated.
Regards, Keith
