I have a Lev 6417 motion sensor that I want to disable on weeknights. I have a lev 6311 programmer set to turn off a Lev 6291 that is feeding the Lev 6417 motion sensor on weeknights. The funny thing is every time I try to turn the 6291 off remotely (via X10), it clicks off and right back on again - instantaneously. However, it can be turned on and off locally with no problems. It doesn't matter what type of transmitter I use; same thing always happens (off-on). However, if I disconnect the Lev 6417 motion form the load side of the 6291, everything is fine. If then reconnect the 6417 back up to the 6291 load and place a 60W light bulb on the load side of the
6291 in parallel with the 6417; it works fine. Anyone seen this before? Why would this be? TIAPaul
