I am installing a new home network with approximately 24 Cat6 runs that I plan to terminate to a patch panel in my basement. I am planning on using a patch panel that allows me to snap in keystone jacks. Should I use any particular type of keystone jack for the patch panel or will the Cat6 keystone jacks I use for the wall plates do the job? I have seen "High Density (HD) Category" Jacks advertised on websites and wonder if they are necessary. I am concerned about inteference between the jacks. Thanks.
- posted
18 years ago
