I have some exterior halogen lighting for my deck that total 450 watts. The lights installed are these:
and
The manual for the lights state they are dimmable, so I am ok there. The kepadlinc (12073) is a 450 watt dimmer. My question is this... Should I use a 450 watt keypadlinc dimmer for these lights, since the wattage load is right at the maximum allowed? Will the dimmer heat up? Will it buzz when load is on?
