I have a homeplug ethernet powerline network
- posted
18 years ago
"killed the network" is rather general. Can you be more specific?
Is the network affected 100% of the time or only when the Keypadlinc is transmitting X-10?
Have you had other X-10 devices that work? If so, how long have you used them with the network?
I suspect you have a defective Keypadl>I have a homeplug ethernet powerline network
Hi Dave! The upstairs computer no longer recognizes the downstairs computer, once the keypadlinc was installed... The network is affected
100%. I have been using a Leviton 6308 photocell controller for a year or so with no troubles but I suspect the keypadlinc draws more current or something...It's more likely that the Keypadlinc has a line filter that is attenuating the (much) higher frequencies used by Homeplug. Some *linc modules have exhibited problems with high frequency 'noise' on the line so they may have taken a shotgun approach.
Levit>Hi Dave! The upstairs computer no longer recognizes the downstairs
Thanks Dave! It looks like I will have to go to a wireless network since I plan to install more of these keypadlincs. The keypadlincs seem like a good product but they seem a little quirky with any type of noise or anything for that matter on the powerline. Every time my furnace kicks on, the keypadlinc blinks!
