Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Chip Orange on August 6, 2005, 9:32 pm
Please log in for more thread options I have several X10 lights which suddenly stopped responding, intermittently, to X10 signals. by turning on and off some 220V appliances, I've come to believe that it's a failure of the whole-house signal bridge, about 10 years old. Since this is a completely passive system (my understanding anyway), I'm not sure how it could fail, but I wanted to ask here if having it replaced by an electrician is a reasonable effort at problem solving, since I can reliably make these switches respond by turning on 220V appliances? thanks. | ||||||||||||||||
Posted by Robert Green on August 6, 2005, 9:54 pm
Please log in for more thread options > Since this is a completely passive system (my understanding anyway), I'm
not
Capacitors fail all the time. Do a Google search on: "capacitor failures" To read an interesting article about the recent scandal over bad capacitors that had a serious effect on the PC world: FAULTS & FAILURES Leaking Capacitors Muck up Motherboards "It has all the elements of a good thriller: a stolen secret formula, bungled corporate espionage, untraceable goods, and lone wolves saving the little guy from the misdeeds of multinational corporations. In this case, a mistake in the stolen formulation of the electrolyte in a capacitor has wrecked hundreds of PCs and may wreck still more in what is an industrywide problem. Aluminum electrolytic capacitors with a low equivalent series resistance (ESR) are high-capacitance components that generally serve to smooth out the power supply to chips. Throughout 2002, they have been breaking open and failing in certain desktop PCs. Motherboard and PC makers contacted by IEEE Spectrum have stopped using the faulty parts, but because the parts can fail over a period of several months, more such failures are expected . . . " continued at: http://www.spectrum.ieee.org/WEBONLY/resource/feb03/ncap.html -- Bobby G. | ||||||||||||||||
Posted by Chip Orange on August 6, 2005, 10:15 pm
ok, thanks. Is there one particular brand of passive bridge to be preferred to another? I live in a small town, so I'll just order one, and then get an electrician out (since we won't have anyone in town who stocks this). >
> not
> Capacitors fail all the time. Do a Google search on: "capacitor > failures" > > To read an interesting article about the recent scandal over bad > capacitors > that had a serious effect on the PC world: > > FAULTS & FAILURES > Leaking Capacitors Muck up Motherboards > > "It has all the elements of a good thriller: a stolen secret formula, > bungled corporate espionage, untraceable goods, and lone wolves saving the > little guy from the misdeeds of multinational corporations. In this case, > a > mistake in the stolen formulation of the electrolyte in a capacitor has > wrecked hundreds of PCs and may wreck still more in what is an > industrywide > problem. > > Aluminum electrolytic capacitors with a low equivalent series resistance > (ESR) are high-capacitance components that generally serve to smooth out > the > power supply to chips. Throughout 2002, they have been breaking open and > failing in certain desktop PCs. Motherboard and PC makers contacted by > IEEE > Spectrum have stopped using the faulty parts, but because the parts can > fail > over a period of several months, more such failures are expected . . . " > > continued at: > http://www.spectrum.ieee.org/WEBONLY/resource/feb03/ncap.html > > > -- > Bobby G. > > > > | ||||||||||||||||
Posted by Robert Green on August 6, 2005, 10:54 pm
preferred
> to another?
Most people find it preferable to switch to an active coupler a.k.a. a repeater. That's because more and more consumer products (compatc fluorescents bulbs, UPSs and switching power supplies) are turning out to be X-10 signal suckers. An investment in a repeater now might save lots of trouble in the future like having to buy lots of filters or calling the electrician back to installer a repeater. Both ACT and Leviton make units in the under $100 range. Check Smarthome for a plug-in unit. You can get either a repeater or a coupler in a model that plugs into a 220VAC outlet. Not as good as a panel mounted unit, but good enough. Saves on calling in the electrican. -- Bobby G. | ||||||||||||||||
Posted by Chip Orange on August 7, 2005, 1:10 pm
Thanks; I don't mind spending for a repeater, or an electrician, it's just I thought I had read once that repeaters had their ocasional problems (such as the destination device receiving both the original dim command and then the repeated one, so it would dim more than desired?). thanks. >> ok, thanks. Is there one particular brand of passive bridge to be
> preferred
>> to another?
> Most people find it preferable to switch to an active coupler a.k.a. a > repeater. That's because more and more consumer products (compatc > fluorescents bulbs, UPSs and switching power supplies) are turning out to > be > X-10 signal suckers. An investment in a repeater now might save lots of > trouble in the future like having to buy lots of filters or calling the > electrician back to installer a repeater. Both ACT and Leviton make units > in the under $100 range. > > Check Smarthome for a plug-in unit. You can get either a repeater or a > coupler in a model that plugs into a 220VAC outlet. Not as good as a > panel > mounted unit, but good enough. Saves on calling in the electrican. > > -- > Bobby G. > > > > > | ||||||||||||||||
| Similar Threads | Posted |
| is it possible for x10 signal bridge to fail? | August 6, 2005, 9:32 pm |
| Signal bridge question? | December 21, 2005, 2:11 pm |
| X-10/UPB Bridge Documentation | January 18, 2006, 4:40 pm |
| X-10 TW-523 --> UPB bridge and converter | December 1, 2007, 6:02 pm |
| X10 signal levels | July 28, 2005, 2:05 pm |
| X10 signal problems... | October 18, 2005, 10:48 am |
| mystery signal | November 11, 2005, 11:02 am |
| Best Way to Amplify X-10 Signal? | March 1, 2006, 7:13 am |
| X10 to Wireless signal | July 20, 2007, 8:26 pm |
| X10 signal amplitude | September 13, 2008, 4:53 am |
| CVBS video signal | April 4, 2005, 3:08 pm |
| Measuring X10 Signal Strength. | May 25, 2005, 8:53 pm |
| a phantom signal source | December 6, 2007, 8:06 am |
| Splitting a CCTV signal to two monitors | May 4, 2005, 1:16 pm |
| Need to very good booster X10 signal on both phases? | June 28, 2005, 5:46 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
