You might notice from previous posts that I know nothing about electricity. I thought maybe someone in this forum could give me some guidance on how to complete this project.
I boght the following sensor
The problem is that this seems to be a low voltage device and the light bulb is 120Volts. I don=92t think I should just send electricity form the power outlet directly to this switch.
Does anyone have any idea how can I turn on/off a 120Volts light bulb using this low voltage switch?
Thanks in advanced.
