Hi everyone,
I have two XBees set up for digital I/O line passing: One XBee is connected to a toggle switch bank, and another to receive and output the signals on a LED bank.
Everything is fine up to this point.
However, I have problem implementing the sleep mode for I/O line passing. Using this article
, the XBee now successfully sleeps half the time, and changes the output accordingly when its awake. However, the XBee continues its sleep cycle even when the output is changed. Is there anyway I can set the receiving XBee so that it wakes from sleep mode if the controlling XBee is switched on?
Help would be greatly appreciated.
isoboy
