Hi
I just started using Active Home Pro. I am having a heard time setting the timers. I think it is because I have other languages installed on my computer and some of the text doesn't show up readable in the program. As a result, I cant change the times with the buttons. It would be great if I could type in the lines to execute my commands.
Anyways...What other software is out there and in use? I would really like to be able to type text files and import that into the software. Kind of like:
06:30 A10 Turn On 06:30 A15 Turn Onis there any software that will allow me t do that?
Thanks Pat
