I have an immediate need to specify a controller for a special project we are doing. I need a logic controller to do the security and the if/then/or stuff. It needs to be ethernet capable with full controllability via a remote system. I do not need any keypad controls or stats or lighting directly supported, we'll do that through our integration software. I mainly need the logic to perform I/O control, provide arming (mode) status, sensor input status, sunrise/sunset and the like. We normally would use HAI, but they don't want to play with others (formats) very well.
Your suggestions are appreciated. You can likely tell I'm new on this, but picking it up fast!
