Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by E. Lee Dickinson on March 30, 2007, 6:03 pm
Please log in for more thread options remember what they're actually called to search for one and to figure out how much they cost. I'm talking about the machines that have a wheel onto which you set, say, "Kitchen speakers" and as you pull the cable through the machine it stamps those words onto the cable at a regular interval. Anyone know where to get one, how much they cost, or what they're actually called? Thanks! E. Lee Dickinson Entertainment Design and Technology www.leedickinson.com | |||||||||||||||||||
Posted by Robert Green on March 30, 2007, 7:49 pm
Please log in for more thread options > I know these machines have been discussed in this group before, but I
can't
the
> how much they cost. I'm talking about the machines that have a wheel onto > which you set, say, "Kitchen speakers" and as you pull the cable through > machine it stamps those words onto the cable at a regular interval.
> > Anyone know where to get one, how much they cost, or what they're actually > called? I think they are called: http://www.taymer.com/html/hot_stamp_wire_marker___contin.html Those are industrial machines - perhaps there's something smaller. I have the big box of Crayola crayons. I hold one against the wire (I use mostly white cable) as I pull it from the box. That stripe usually is enough to help me ID the cable when it's actually through the holes. I think there are 78 colors, although there really are a dozen or so I can distiguish without error. -- Bobby G. | |||||||||||||||||||
Posted by Robert Green on March 30, 2007, 7:59 pm
can't
the
> > Anyone know where to get one, how much they cost, or what they're actually > called? This might be more to your liking: http://www.emcsolutions.com/hz2-wire-marker.html -- Bobby G. | |||||||||||||||||||
| Similar Threads | Posted |
| heat imprint cable marker | March 30, 2007, 6:03 pm |
| LED Security camera heat question | September 2, 2006, 11:29 am |
| Pool Heat Automation Suggestions | September 20, 2007, 2:50 pm |
| IR cable: can I use CAT-5? | December 29, 2005, 7:04 pm |
| Expensive cable! | April 20, 2008, 9:50 am |
| best cable for video camera | February 14, 2005, 11:13 am |
| Powerfast Cable Tacker | March 25, 2005, 11:36 am |
| x10 CM12u Serial cable Help | April 8, 2005, 11:33 pm |
| which size of OFC loudspeaker cable should I use? | May 22, 2005, 3:10 pm |
| Network & TV cable question | July 21, 2005, 2:48 am |
| POTS and Ethernet over CAT-5 Cable | August 14, 2005, 3:08 pm |
| Detecting where a coax cable goes to | January 21, 2006, 6:38 pm |
| Cable-pulling Humor | February 13, 2006, 3:53 pm |
| RF Modulator and Cable Modem | October 12, 2006, 12:16 am |
| Wireless Cable Info | November 4, 2006, 12:29 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
