Forwarding RTSP port to multiple IP Cams
I would like to hear from those of you who operate several IP cameras behind a router's firewall which all require forwarding the same RTSP port 554. How do you configure your router for that so you can watch the live video stream from outside (the WAN side?)
Most cams allow the use of not just the default port 80 for their HTTP interface, so the different HTTP ports can easily be forwarded to the right LAN IP of each cam, but as far as I know, they don't allow different RTSP ports to forward to each cam. Yet, I know such cameras do operate out there so I wonder how. I would appreciate any help in this issue.
Rover
