DVI digital over VGA cable
Does anyone know of an adapter that will allow me to run a DVI-D signal through a VGA cable (turn a VGA cable into a DVI-D cable)?
Problem is that my computer has a DVI output, and my flat-screen TV in another room has a DVI input (digital only) but the only wire running through the walls is a VGA cable.
When I google it I am only finding results for adapters to go from DVI to VGA.
I did try a standard DVI to VGA adapter on both ends and it didn't work. I think it is only passing the analog part of the signal so there is nothing to "convert back" at the digital end.
Thanks
Jack B. Pollack
