Sorry if this has been covered already, but I am looking for a way to deal with this DST issue. I thought I'd be able to simply synchronize my computer clock with the NIST time servers after the switch over and all would be well. Today I found out that won't work. Only one of my
5 computers has an OS that can be patched, so I am left with 4 Windows OS's that will need manual adjustments unless I can figure something out.Syncing to GMT on the internet, and then running a variable offset that is triggered by the calendar would work nicely. I suppose I could write a perl script that does this, and then use task scheduler to run it once a day. Maybe I could sync to the patched computer on my network and not have to worry about the extra offset and calendar logic. Is there a way to remotely sense an XP SP2 computer's system time?
