I am trying to get my "Visual Message Wating? back after installing DSL.
Before I had DSL, My device worked fine. I uses the Side tones, just like Caller-ID, to Set or extinguish a lamp depending on what voicemail tells it to do.
After installing DSL, and the filters to keep the HISS undercontroll, my lanp no longer works. I even tried getting one of the "Dynamic" DSL filters that is supposed to address just this issue.
On the odd chance it was my device, I tried another box...same thing.
Any ideas? Is there a way to boost the sidetones so they make it through?
Trying to work with Verizon is a pain. The Non-Agents on the phone work from a script...."DO you have dial tone, have you tried it at the NID...etc..."
Any help would be appreciated.
