General Home Automation distribution of HTPC's VIDEO + AUDIO
Subject Author Date
distribution of HTPC's VIDEO + AUDIO Marky 04-03-05
Posted by Marky on April 3, 2005, 6:14 pm
Your advice please.
I would like to distribute VIDEO (preferably VGA) + AUDIO + a spare
3-wire signal (#see footnote) over CAT5e and/or COAX.
I'm using a home-theatre pc (HTPC) as my entertainment hub in the
living-room for freeview/music/DVDs/games. The VGA-port on my videocard
simultaneously outputs a very crisp 856x480px image to my Loewe TV; and
the DVI-port outputs 1024x768px to my projector.
However, I'd now like to add a 17" TFT-monitor to the bedroom, and
watch, listen & remote-control whatever is being displayed on the HTPC
downstairs.
My house is CAT-5e pre-wired (including patch-panel), so I think it's
best to utilise this infrastructure to distribute the necessary signals
to the bedroom TFT, rather than use wireless technology.
There is 1x CAT5e wall-plate free in each room, and 1x COAX cable wall
plate (quality unknown) free in each room.
From what I can see I have three options:
1) VGA distribution:
* Use a VGA-splitter (because I still need the VGA signal locally),
then distribute the duplicate VGA-signal using a 'VGA over CAT5e
distribution' box solution.
* Disadvantage:
Still need someway of controlling the HTPC remotely, as all wires
in the CAT5e cable would have been used for video+audio transmission.
2) Modulation:
* Use a VGA-splitter and a VGA-modulator in the Living-Room to
encode the VIDEO+AUDIO into a single-channel that will then be fed
through to the Bedroom and connected to the TFT TV (rather than a
monitor). In terms of control, I can send serial signals (#see
footnote) over the free CAT5e to the Living-Room HTPC.
* Disadvantages:
I've heard modulators are costly,
Requires the use of both two cables,
Perhaps the signal-quality of the 856x480px VGA signal will not
modulate well (?)
3) S-video disbribution:
* Use a VGA-splitter and a VGA>S-video convertor connected to one of
the many all-in-one 'AV CAT5e distribution + IR control' box solutions
I've seen on the net. S-video routed to TFT MONITOR in bedroom.
* Disadvantages:
Picture quality of s-video is not as crisp as the original VGA
signal which is a shame because of the quality potential the bedroom
TFT-monitor could offer.
Perhaps I will be limited to standard TV S-video resolutions?
(640x480, 800x600)
I may have problems utilising the bundled IR-control distribution
method with my existing IR-control hardware (#see footnote)
* Subject to further tests, I *may* be able to output s-video from
my video-card (ATI Radeon 9600XT) simultaneously as the VGA+DVI signals
(?) and therefore avoid the whole VGA-splitter & VGA>S-video conversion.
#footnote:
I have an IRtrans USB device inside my HTPC that allows me to receive
IR-signals from any remote and act on it accordingly (software). I also
have a extender-module that can be located remotely and used to send
IR-signals from the bedroom back to the main-module in the living room.
Distribution of the signal requires 3 seperate wires.
Any advice will be much appreciated,
Mark.
Similar ThreadsPosted
distribution of HTPC's VIDEO + AUDIO April 3, 2005, 6:14 pm
Audio / Video Distribution October 13, 2005, 11:19 am
Audio Video Distribution Questions October 21, 2005, 9:54 am
Home video distribution? March 21, 2005, 3:21 am
Video Server and Distribution June 12, 2006, 11:22 pm
Home RF video distribution November 7, 2006, 7:04 pm
Distribution of video signal to multiple TV using a matrix April 3, 2007, 5:39 pm
Crestron plans for digital video distribution? June 17, 2008, 9:28 am
Zon Audio distribution question April 24, 2005, 8:56 am
Help: home audio distribution scheme April 30, 2006, 12:16 am
Whole House Audio/Video August 20, 2005, 3:21 pm
audio video multimedia setup August 22, 2006, 10:38 pm
OFF AIR DISTRIBUTION SWITCH January 14, 2006, 5:36 pm
OFF AIR DISTRIBUTION SWITCH January 14, 2006, 5:39 pm
Multi-Speaker Distribution October 1, 2005, 12:37 pm
