A long time ago I remember seeing sheilded cat 5. There is one big problem with sheilded. You can only ground 1 end not both. I've also seen cable that is sheilded and looks like cat 5. The problem with this stuff is the impedance of the cable is out of spec and will cause all sorts of problems.
