General Home Automation control motion/occupancy sensor using PLC[2414U]
Subject Author Date
control motion/occupancy sensor using PLC[2414U] arnie 07-19-07
Posted by arnie on July 19, 2007, 4:22 am
Hi
I want to control occupancy sensor [PMS02] and motion sensor [MS14A]
using powerlinc V2 controller USB [2414U]. There is also an RF
transceiver present in the circuit. Manually i be able to control the
x10 PRO modules using the motion sensor/transceiver combination. The
lamp module is LM465.
I want to control the motion sensor/occupancy sensor using PLC but no
idea about how it can be done
Can anyone suggest steps [if possible]
Thanks
Arnie
Similar ThreadsPosted
Re: Control occupancy sensor/motion sensor using Powerlinc V2 controller July 19, 2007, 7:03 am
Re: Control occupancy sensor/motion sensor using Powerlinc V2 controller July 19, 2007, 7:14 am
Control occupancy sensor/motion sensor using PLC July 19, 2007, 1:16 am
control motion/occuupancy sensor using PLC [2414U] July 19, 2007, 3:25 am
control motion/occupancy sensor using PLC[2414U] July 19, 2007, 4:22 am
Control motion/occupancy sensor using PLC [2414U] July 19, 2007, 5:48 am
control motion/occupancy sensor using PowerLinc controller usb [2414U] July 19, 2007, 2:38 am
FS: JP1 cable to program your universial remote control, now youcan control anything you want! July 14, 2005, 10:46 pm
pir motion sensor October 25, 2005, 3:35 am
Motion Sensor on 3-Way July 29, 2007, 11:31 am
sensor controller October 8, 2006, 12:08 pm
X10 Motion Sensor January 8, 2007, 1:39 am
Outdoor temperature sensor . . .` January 30, 2006, 2:49 pm
2 wire sensor interface June 14, 2006, 8:12 am
Motion Sensor With LED's March 5, 2007, 1:59 pm
