Does anyone know of a cheap (less than $50) temperature sensor (indoor ambient) with an Ethernet port? Something with a built-in web browser and/or TCP/IP socket interface that would allow me to see the temperature in a room via a network.
If you want to ethernet-enable those devices (and know Java) you can use the Dallas TINI board which has a 1-wire bus and ethernet ability.
But as Steve mentioned setting up a 1-wire network and connecting to an existing PC is really the easy approach. Here is a open source project which uses this same system for HVAC zoning control.
I agree that it can't be done for less than $50 today although I don't agree with your cost figure. Mouser has the Lantronix xPort for $49 and it's about $35 in OEM quantities from Lantronix. Add a PIC and thermistor and the cost is just over $50 even for one off.
This will shortly change. Microchip has announced a single chip Ethernet interface (ENC28J60) and Digikey lists it for under $10 in single quantities. Once it's available it will be economical to Ethernet enable almost any µController based project (assuming the µController has enough horsepower). If you use the QFN28 package it won't even require much board space.
