Well, you see, the house is infested with bats and though we're trained the werewolf puppies to use the vacuum cleaner to suck up the dead bats and not eat them, the bats are just the right size to plug the house. The little werewolf pups are still learning, so they can't tell when the damn thing gets clogged. Then the forget their training and eat the bats when they don't go down the tube, get rabies and begin to drool all over the carpet from hydrophobia so the that agitates Cujo, who comes and fights with the werewolves and all Hell breaks out. So you can see why it's a problem.
The serious answer is that with a motorized head, there's sufficient sweeping action to appear as if the vacuum is sucking things in. Couple that to the "silencer" cabinet I built around it, it actually IS hard to tell when vacuum is lost and the motor is making a high pitched noise - which could indicate that I already have the relief valve that I am thinking of buying and should test to see if the outlet air is still flowing when the hose is clogged. That would indicate that the unit itself has opened an internal bypass valve. Good work, George. You may be on to something . . .
Anyone still reading: Why DOES the motor RPM increase quite noticeably when the hose is clogged. Does an internal vacuum relief valve sense the blockage and open a relief valve? Since it would be close to the vacuum motor, probably in the head, it would not have to draw air from the entire piping system and thus the motor RPM would soar because of the lightened load. Sound right?
-- Bobby G.
