Hi Can Axis 207W camera be connected to an ADSL modem [ethernet connection]. This setup is part of home automation.I want to configure modem for axis camera. Tell me if this is possible Thanks Arnie
- posted
16 years ago
How to get the IP address of the axis camera in this connection to adsl modem Thanks Arnie
"arnie" schreef in bericht news: snipped-for-privacy@e16g2000pri.googlegroups.com...
Yep, it is possible. You can either connect it using a wired (UTP) connection, or you can use the wireless connection. In order to get the wireless connection to work, you first establish a wired connection, then you can change the ettings of the
207 after which it can use a wifi connection. local IP adress is provided by the modem (It is best if you make sure the modem always give the same adress to the camera, otherwise NAT will soemtimes stop working.Cabling-Design.com Forums website is not affiliated with any of the manufacturers or service providers discussed here. All logos and trade names are the property of their respective owners.
