From a leading engineer in the CATV industry: "We did a scientific research for a year on CPD and contact interfaces, the report shows us that it is very important to break through the oxide layer to prevent a non-linear behavior in contact surfaces. The torque varies with the type of plating used on the F-connectors.
Finger tight is not tight enough to break through the oxide layer, and due to temperature cycles it will loosen up after a while. Especially in the neighborhood of the subscribers and RF output of the node it is important, (the effect of a loose or bad connection is the biggest at those points) to have proper contact interfaces.
CPD ? This phenomenon, also known as Common Mode Distortion, is generally the result of age and corrosion in the cable plant connectors. This non-linear function is commonly caused by oxidation of metal surfaces, creating a point contact diode. Should the diode effect occur on the ground portion of a connector, common mode distortion and ingress are likely. The effect that this diode phenomenon causes is observed as difference products in the return plant, and can be caused by one or more faulty connectors.
In general, interfering products will be observed at harmonic intervals of 6MHz throughout the return plant band. Sidebands of this will tend to raise the apparent noise floor. Because common mode distortion is a non-linear effect, slight variations in the point diode structure due to temperature, humidity, wind velocity, etc. have a significant impact on the interfering levels observed."
Manufacturers and the engineering community in the CATV industry recommend they be tightened to 30-in/lbs. The best that can be achieved by hand is less than 13.
CIAO!
Ed N.
Robert L Bass wrote:
more than "finger tight." The electrical connection is
stresses the connection between the cabinet and the
