wrote
Yes, but the major company supplying the one-at-a-time units appears to be in flux. More importantly, research has indicated that motor and solenoid noise will probably be more disruptive to the other dogs than reinforcing to the target dog, at least in the mode I was intending to use. That's going to restrict what I am able to do. It has me thinking my first step should just be to analyze their reaction to momentary activation of a high-torque motor before I sink lots of time and effort into building the actual device. That would be pretty easy to test.
See my note to BF about the revolving pistol cylinder design, which I think you're describing above. Feed hopper feeds rotating cylinder with round cylindrical compartments around the edge, inserting a pellet into each empty one that passes under it. There's a hole on the bottom plate that the cylinder rotates upon that lets a pellet drop when a full cylinder hole is rotated into position above it. Wouldn't require a stepper motor, per se, just a motor with enough torque to advance the cylinder to drop a pellet or two after a momentary activation.
All this got me to thinking. California used to use pellet dropping as the ultimate sanction of *bad* behavior, as in the cyanide pellets used in the gas chamber.
-- Bobby G.
