Anyone out there that can compare Charmed Quark to Girder?
I'd like to web-enable certain aspect of my system and have been looking at both Charmed Quark and Girder. There's an enormous price difference. Is there a correspondingly enormous quality or value difference?
-- Bobby G.
Robert Green
Girder automates PC apps and has some pretty handy integration features for devices. CQC is a whole suite of automation apps designed for client/server operation. They're entirely different things.
Bill Kearney
client/server
I just bought an IRTrans USB Translator device, capable of receiving one IR code and outputting another code or series of codes from its internal database. I got it so that when I got new gear for the AV room, I wouldn't have to reprogram all the learning remotes around the house. One session of learning and translating codes and the new device can be operated from the same old remotes via the Powermids. More on that later in a separate thread.
One of the pieces of SW that's cross-supported by the IRTrans device is Girder Pro. When I first began researching the IRTrans USB Translator I saw a lot of references to Girder Pro. From what I can tell, I think the souped up "pro" version is much more than just an "app" automator and integrator. The plain version appears to work as you describe, but the "pro" version:
sells for $149 and Smarthome claims:
Robert Green
They have a whole house licesnse for $200.
Promixis has a forum at...
It will probably give you some idea of how others are using Girder Pro.
Dave Houston
