Excuse me, in AMX there is one function how this: ?
Name:
High
Syntax:
INTEGER High(INTEGER VALUE);
Description:
Returns the upper most significant 8-bits of an Integer.
Parameters:
VALUE is an integer containing the value of the most significant byte. It is not sign extended.
Return Value:
The upper 8-bits of the passed value. The return value is not signed extended, It is intended only for unsigned short integers (16 bits).
Example:
ANALOG_INPUT VALUE;
CHANGE VALUE
{PRINT("The upper byte of %X is %X\\n", VALUE, HIGH(VALUE))
}This will print the input value and the upper 8-bits of the value in hexadecimal. For example, if VALUE is 0x1234, then the output is The upper byte of 1234 is 12.
