I've got about 70 X10 receivers (dimmers, switches, appliance modules and lamp modules) in my house today. Almost all of these are Smarthome (some are Leviton).
I need to add about a dozen or so new modules (some inline modules, new lamp modules, appliance modules, relays and dimmers).
My question is: should I stick with X10 modules or go with the Insteon modules?
I have no immediate plans to switch to Insteon, but I'm wondering if it is wise to get them to give me this option in the future.
I'm also concerned with signal attenuation. It's my understanding that the Insteon modules suck signal the way the 2-way modules do (but I will probably add a few 2-way X10 modules anyway).
Thanks for any inputs you have!
Mitch
