Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Dave Houston on December 6, 2007, 8:06 am
Please log in for more thread options mode power supplies (SMPS) spontaneously generating valid X-10 PLC codes. Bruce Robin sent a noisy SMPS (in a charger) that was blocking X-10 activity to Jeff Volp who ran some tests. AFAIK those tests failed to show any spontaneously generated X-10 codes. There was a recent thread on Smarthome's Insteon forum that, in part, discussed phantom PLC codes being logged that went away when a CFL (with an apparently noisy SMPS) was removed from the mix. Further investigation found that the source of the apparently spontaneous codes was actually an ACT CR134 coupler/repeater. When it was replaced with a plug-in passive coupler, the phantom codes disappeared. Another factor was that the phantom codes only appeared after a valid Status Request was transmitted. http://davehouston.net http://davehouston.org http://tech.groups.yahoo.com/group/roZetta/ roZetta-subscribe@yahoogroups.com | |||||||||||||||||||
Posted by Jeff Volp on December 6, 2007, 9:41 am
Please log in for more thread options charger: http://jeffvolp.home.att.net/x10_info/x10_Cellet_noise.htm However, if you look at the 3rd photo down, you can see the ESM1 giving a solid "X10 Good" indication when the charger was loaded with 20 ohms. I was testing how well the XTB-IIR AGC rejected the noise, and I did not see it accept the signal as valid even though the ESM1 seemed to be happy with it. Jeff | |||||||||||||||||||
Posted by Dave Houston on December 6, 2007, 10:15 am
Please log in for more thread options The ESM1 does not do a thorough manchester check but only counts the number
of 1 bits and 0 bits that follow a 1110 (presumed to be a start code). Thus 11101111111111100000000000 is only one of many non-X10 sequences that might cause the X10 Good LED to illuminate. >I did not monitor X10 line traffic while testing the Cellet cellphone
>charger: > >http://jeffvolp.home.att.net/x10_info/x10_Cellet_noise.htm > >However, if you look at the 3rd photo down, you can see the ESM1 giving a >solid "X10 Good" indication when the charger was loaded with 20 ohms. I was >testing how well the XTB-IIR AGC rejected the noise, and I did not see it >accept the signal as valid even though the ESM1 seemed to be happy with it. > >Jeff > >>A while back there was a thread here about the possibility of noisy switch
>> mode power supplies (SMPS) spontaneously generating valid X-10 PLC codes. >> Bruce Robin sent a noisy SMPS (in a charger) that was blocking X-10 >> activity >> to Jeff Volp who ran some tests. AFAIK those tests failed to show any >> spontaneously generated X-10 codes. >> >> There was a recent thread on Smarthome's Insteon forum that, in part, >> discussed phantom PLC codes being logged that went away when a CFL (with >> an >> apparently noisy SMPS) was removed from the mix. Further investigation >> found >> that the source of the apparently spontaneous codes was actually an ACT >> CR134 coupler/repeater. When it was replaced with a plug-in passive >> coupler, >> the phantom codes disappeared. Another factor was that the phantom codes >> only appeared after a valid Status Request was transmitted. >
| Similar Threads | Posted |
| a phantom signal source | December 6, 2007, 8:06 am |
| Open Source | February 5, 2008, 5:25 pm |
| Source for Lutron or Vantage? | August 31, 2005, 10:52 am |
| Parts Source needed | April 24, 2007, 6:16 pm |
| HAI Communicating Thermostat source code? | August 27, 2005, 7:21 am |
| Distro Cable Parts Source | January 12, 2006, 6:00 pm |
| Open Source Thermostat and more (Schematics) | February 21, 2006, 2:08 am |
| Looking for a source of Alarm Screens, or related info | September 10, 2006, 10:55 pm |
| Wanted: Source for tiny audio amps that use DC power | October 17, 2005, 5:39 pm |
| X10 signal levels | July 28, 2005, 2:05 pm |
| X10 signal problems... | October 18, 2005, 10:48 am |
| mystery signal | November 11, 2005, 11:02 am |
| Best Way to Amplify X-10 Signal? | March 1, 2006, 7:13 am |
| X10 to Wireless signal | July 20, 2007, 8:26 pm |
| X10 signal amplitude | September 13, 2008, 4:53 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
> activity
> an
> found
> coupler,
