General Home Automation Z-Wave Pool Thermostat with Water Temperature Sensor
Subject Author Date
Z-Wave Pool Thermostat with Water Temperature Sensor Richard Kaplan 09-23-07
Posted by Richard Kaplan on September 23, 2007, 8:09 pm
I am researching options to control a pool heating system as part of a
home automation system.
The Homeseer website lists a Z-wave thermostat (TZ40) from a company
called RCS, which also makes an optional remote pool/spa temperature
sensor (RSP2).
My thought is that I would install the TZ40 and RSP2 very close to my
pool pump/plumbing. Then I would set up a computer with home
automation software and a z-wave receiver elsewhere in thse house
(probably Homeseer with the Maestro Heat & Air Plug-in.
I got a technical service reply from RCS, however, saying that the RSP2
is discontinued and RCS no longer offers any type of pool/spa control.
Also RCS suggets that "this may not be too practical a use for z-wave
topology since it's a mesh network type of RF transmission and requires
retransmitters out to the pool pad area."
Are there other manufacturers who make a z-wave thermostat with a pool
water sensor? Is it true that z-wave is not a practical use for this
application? If so, what other design would be better?
Posted via a free Usenet account from http://www.teranews.com
Posted by b_weijenberg on September 24, 2007, 1:54 am
Hi Richard,
You can use an Oregon Scientific water temp sensor THWR288.
The Homeseer xAP plug-in supports this type of sensor already and the
ACRF2 plug-in will support it in the near future.
To receive the Oregon sensors you need an RFXCOM 433.92MHz receiver.
RFXCOM has USB connected receivers and using the newest Ethernet
connected receivers you can put your Home Automation receivers and
transmitter now on the optimum location for receiving all sensors in
your property. No longer problems with RF noise radiated by the PC.
Simply put the receiver at a larger distance from the PC with a LAN or
WLAN connection and it makes the receiver now more sensitive.
If the Ethernet interface is connected to the Internet it enables you
to add remote locations to your Home Automation system. Connect your
holiday home to receive the security sensors, temperature and humidity
and switch X10 or control Harrison curtains or even control and check
the home of your grandmother.
All existing Home Automation software that runs on a Windows platform
and has interfacing software for the W800RF receiver or the RFXCOM
receiver can use the RFXCOM Ethernet interface without any
modification in the HA software thanks to the CPR (COM Port
Redirector) software. This CPR software emulates a standard COM port
in Windows.
On other platforms like Mac and Linux, the communication protocol is
via TCP/IP with the receivers and transmitter. Of course, TCP/IP
communication is also possible on the Windows platforms.
All RFXCOM receivers have a W800RF compatible receiving mode and the
RFXCOM receiver translates all received non-X10 RF packets (like
Visonic, SecureLinc, KlikOn-KlikOff, Domia Lite) to an equivalent X10
packet. This makes it possible to process those non-X10 sensors and
remotes by all X10 oriented Home Automation software without any
modification in this Home Automation software.
There are 4 different types of RFXCOM Ethernet interfaces.
1. LAN with 1 COM port and connections for 1 or 2 receivers OR 1
transmitter,
2. WLAN with 2 COM ports and connections for 1 or 2 receivers AND 1
transmitter,
3. LAN with 2 COM ports and connections for 1 or 2 receivers AND 1
transmitter,
4. WLAN+LAN with 2 COM ports and connections for 1 or 2 receivers AND
1 transmitter.
http://www.rfxcom.com/receivers.htm
Bert
> sensor (RSP2).
> Posted via a free Usenet account fromhttp://www.teranews.com
Posted by Richard Kaplan on September 24, 2007, 2:15 am
Thanks... it looks like that would work as a standalone thermometer.
What I am looking for though is a thermostat, not just a thermometer.
I would like this thermostat to sense the temperature in my pool and
then control my pool heater. Any idea how I can do that?
Posted by Dave Houston on September 24, 2007, 6:42 am
Let me understand this - a manufacturer of a Z-Wave thermostat has told you
this is not a good application and you still to use Z-Wave for this? While
you may find greedy dealers who neither know nor care about suitability, you
should give a lot of credence when a manufacturer indicates you should look
elsewhere.
In general, Z-Wave and all other FCC-compliant RF devices have limited range
(although, outdoors with no obstructions is "best case"). Z-Wave and some
other mesh networks overcome this by using multiple units to relay the
signals but Z-Wave has a maximum number of hops (4 in the standard setup)
which limits the maximum distance even with multiple units. There are also
some issues with feedback from Z-Wave devices and Z-Wave devices relay the
signal sequentially so there are delays proportional to the number of hops.
I would not recommend RF as the heart of the system for this application.
There are numerous companies that specialize in automated pool controls.
Google using "pool automation" and you will be overwhelmed with choices.
Posted by Richard Kaplan on September 24, 2007, 9:31 am
Yes and no. They NO LONGER manufacture z-wave thermostats. Granted,
maybe that means it didn't work well.
But the distance involved here is no more than for any other devices in
my house. Is distance the only concern?
Yes and no. Jandy's system for example is apparently proprietary and
cannot be operated over the Interernet except with some major hacking.
And Intermatic uses z-wave technology on a dedicated pool automation
system - so why does it work there?
What "official" or dedicated pool automation system which doesn't use
z-wave can be operated via the Internet?
Similar ThreadsPosted
Z-Wave Pool Thermostat with Water Temperature Sensor September 23, 2007, 8:09 pm
Pool Temperature Monitoring December 9, 2006, 4:10 pm
Outdoor temperature sensor . . .` January 30, 2006, 2:49 pm
Hot Water Lobster (Hot water circulation system) March 22, 2005, 1:48 pm
Re: Control occupancy sensor/motion sensor using Powerlinc V2 controller July 19, 2007, 7:03 am
Re: Control occupancy sensor/motion sensor using Powerlinc V2 controller July 19, 2007, 7:14 am
Control occupancy sensor/motion sensor using PLC July 19, 2007, 1:16 am
Pool controls - what are my options? February 6, 2005, 9:42 am
Pool Valve Control August 22, 2005, 7:55 pm
Swiming pool alarm January 29, 2007, 7:58 pm
Temperature monitoring March 10, 2007, 1:20 am
Temperature Concerns March 22, 2007, 12:10 pm
Pool valve X10 automation question February 28, 2005, 11:43 pm
Pool Heat Automation Suggestions September 20, 2007, 2:50 pm
Elk and Zwave March 18, 2007, 12:40 pm
