General Home Automation Xmas is early - with LED lights
Subject Author Date
Xmas is early - with LED lights AZ Woody 11-05-07
Posted by AZ Woody on November 5, 2007, 10:59 pm
Ok, so it's only the beginning of Nov, but I'm staring early!
Got a couple strings of LED lights. (60 on a string, Phillips, from
Target).
In the past, I've used indi C7's and used a std X10 lamp module. No
problem..
Tried the lamp mod with the LEDs, and they don't go off (still dimly lit
when off), so I tried a Appliance Mod - Same thing!
These are old modules I keep with the Xmas stuff, and I don't mind doing
some "surgery".
Ya think this is a "local control" issue with the modules? If so,
what's the website that tells you how to hack the module? (I've lost it
long ago...)
I know I could probably add an inci light and draw enough power to make
this work, but that's kind of against the reason I'm using LEDs!
Merry Xmas! (like two months early!)
Posted by INSPECTOR via HomeKB.com on November 6, 2007, 7:02 am
>Target).
>problem..
>some "surgery".
>long ago...)
http://www.pigselectronics.com/tektips/tektips.htm#RR501
Message posted via HomeKB.com
http://www.homekb.com/Uwe/Forums.aspx/home-auto/200711/1
Posted by Ian Shef on November 6, 2007, 2:34 pm
@news.qwest.net:
> Target).
> problem..
> some "surgery".
> long ago...)
This is due to the current for local control. If you don't want to put a
small light in parallel with the string (a 7.5 watt night light is
sufficient), then you might consider adding more strings of lights.
The alternative is to cut the wire that supplies the current for the local
control feature. This is different from cutting the signal that enables
local control. This information is available someplace on a web site, but
make sure that you get the right information.
Try http://www.remotecentral.com/cgi-bin/mboard/rc-x10/thread.cgi?1532,1
Ian Shef 805/F6 * These are my personal opinions
Raytheon Company * and not those of my employer.
PO Box 11337 *
Tucson, AZ 85734-1337 *
Posted by Neil Cherry on November 6, 2007, 5:53 pm
> some "surgery".
> long ago...)
I was going to give the other folks a bit of a ribbing for not
giving _the_ site for such information but when I went there it
wasn't there any longer. So I did a quick search and found his
new site:
http://www.idobartana.com/
Ido stored the information on cutting the diode in the lamp and/or
appliance module. BTW, if you're using the Smarthome *linc modules
you won't need to do that as they use a lot less current to do their
current sensing.
I'm going to update my web pages with the information.
Linux Home Automation Neil Cherry ncherry@linuxha.com
http://www.linuxha.com/ Main site
http://linuxha.blogspot.com/ My HA Blog
Author of:         Linux Smart Homes For Dummies
Posted by AZ Woody on November 6, 2007, 7:04 pm
I tried the mods (clipping diode in an appliance and lamp module), and
the leds still stay on! Might have to go with the "add a night light"
route....
>> some "surgery".
>> long ago...)
> new site:
> current sensing.
Similar ThreadsPosted
Xmas is early - with LED lights November 5, 2007, 10:59 pm
LED Xmas lights and X10.. the final solution... November 19, 2007, 10:59 pm
early powerline uses May 4, 2005, 4:20 pm
X10 and LED lights December 4, 2005, 4:48 pm
Lights flickering August 30, 2005, 5:41 pm
Keeping lights off at night March 3, 2005, 11:49 pm
LED Lights and other automation protocols April 5, 2005, 8:13 pm
Re: X10 with Compact Fluorescent Lights (fwd) July 13, 2005, 12:10 am
caution is needed with lights! December 8, 2005, 2:02 pm
dimmer lights for house February 12, 2006, 7:10 am
Controling Holiday Lights October 15, 2006, 9:37 pm
Random X10 all lights on/all units off over and over December 9, 2006, 12:05 am
Control Ceiling Lights December 22, 2006, 6:57 pm
X-10, GFCI, outdoor lights & problems June 12, 2005, 1:28 am
Timer recommendation for porch lights August 20, 2005, 7:59 pm
