General Home Automation X10 switch control logic
Subject Author Date
X10 switch control logic J Baber 02-16-05
Posted by J Baber on February 16, 2005, 11:37 am
I have a 3 way hard wired switch for a whole house fan that I want to
replace with non dimming X10 switches. (I do know and accept the X10
reliability factors)
The existing switch has 3 positions HI SPEED | OFF | LOW SPEED. It is
wired 1 wire to power (high) 1 wire to motor Low, 1 wire to motor Hi.
The motor has 3 wires; Hi speed, Low speed Neutral.
I am thinking I can replace this with 2 separate non dimming X10
switches. The 1st would be a ON | OFF toggle style switch, that would
connect the power (hi) to the common contact of the second switch, a non
dimming 2 way ON | ON toggle style switch. One of the 2 switched
contacts to be connected to the motor Hi, and the other switched contact
to be connected to motor Low.
I would mount both switches side by side with the ON | OFF switch to the
left and the HI | LOW to the right for best natural action. One of my
major complaints with the existing switch is that the center OFF is
easy to miss if you are in a hurry, and strangers will almost always use
the WRONG position for the HI / LOW speed. If I mount the switch upside
down we all seem to pick the WRONG one. Using a separate switch (UP for
HI | DOWN for LOW) makes sense from the way that other switches
generally work.
Eventually I intend to use a computer and utilize the X10 control
features to turn a fan on conditionally when the inside temperature
exceeds the outside temperature and the inside temperature exceeds a
predetermined TARGET-TEMP value. The fan would always turn on to the
LOW speed condition, but then if the outside temperature exceeds a
predetermined USE_MAX_FAN parameter after 30 seconds the second switch
would be set to the HIGH speed position. In all cases the turn off
command would reset the speed to LOW.
The fan manufacturer specifies that the fan be started at low speed, but
the supplied switch doesn't force that, and you can see considerable
arcing in the switch if you start it in the high speed position (easy to
do this).
Posted by BruceR on February 16, 2005, 11:23 pm
Is there some reason you don't want to just use an inductive load rated
X10 switch that will adjust fan speed by dim/bright commands.
jimbaber1@comcast.net
> non dimming 2 way ON | ON toggle style switch. One of the 2 switched
> contact to be connected to motor Low.
> the left and the HI | LOW to the right for best natural action. One
> of my major complaints with the existing switch is that the center
> OFF is easy to miss if you are in a hurry, and strangers will almost
> always use the WRONG position for the HI / LOW speed. If I mount the
> switch upside down we all seem to pick the WRONG one. Using a
> separate switch (UP for HI | DOWN for LOW) makes sense from the way
> that other switches generally work.
> but the supplied switch doesn't force that, and you can see
> considerable arcing in the switch if you start it in the high speed
> position (easy to do this).
Similar ThreadsPosted
X10 switch control logic February 16, 2005, 11:37 am
New Google Group for Programmable Logic Control and Automation April 13, 2005, 1:21 pm
How to control the switch using RS-232 April 24, 2006, 4:53 am
New Released - Adaptive Home Logic April 7, 2006, 1:36 am
New update: Adaptive Home Logic v1.01 June 4, 2006, 9:16 pm
Remote Control Power Switch July 28, 2005, 5:24 am
Organizing HA program rules/logic/code June 6, 2005, 5:46 am
CM11A does not get ready for X10-trasmission with Programmable Logic Controller November 19, 2005, 8:05 pm
Zwave In-Wall Switch/Dimmer with RF Remote Control Capabilities January 7, 2007, 9:42 pm
FS: JP1 cable to program your universial remote control, now youcan control anything you want! July 14, 2005, 10:46 pm
Control my PC with a remote control via a USB IR ? October 18, 2006, 2:23 pm
What switch is this August 13, 2008, 9:29 am
Modules switch on every second April 12, 2005, 2:31 pm
In Wall Switch August 26, 2005, 5:52 pm
gate switch December 10, 2005, 10:59 pm
