Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by George Pontis on July 28, 2005, 2:05 pm
Please log in for more thread options While debugging an X10 problem recently I paid some attention to signal levels. I have a Monterey Instruments powerline signal analyzer connected to a power strip that has an appliance module. Under some conditions, the module will not recognize the X10 command. In practice the problematic conditions are when I turn on either some fluorescent lights, or a Sony TV. Both reduce the signal level to about ..26-.29 volts, as displayed by the analyzer. I also checked the noise level using the analyzer, and it remains low (less than 20mv) all the time. It seems to me that a quarter of a volt is plenty of signal for an X10 device to recognize. In practice, I see reliable operation with a PowerHouse AM466 and the Appliancelinc 2002SHL. An X10 Pro appliance module and some Honeywell modules do not recognize the signal. I also tried sending from a different transmitter (CM11A), lest the frequency be in error. Though the signal levels were even lower, in the low 100mV range, the appliancelinc and AM466 still responded. What are reasonable signal levels for reliable X10 with the better switches and modules ? | |||||||||||||
Posted by on July 28, 2005, 11:12 pm
Please log in for more thread options I have found that when I get less than about 1.5 volts, things get unreliable. FYI: APC Powerbars will also drop the volts on outlets that are further away from the circuit breaker feeding the circuit the APC power bar is plugged into. i.e.: breaker--->1stOutletonCircuit--->nextOutletONWall
5volts | 2-3v on next oulet
| V APC Powerbar 4v on APC plugs Sorry for the crude drawing. Using the X10pro filters solves the issue: http://www.x10.com/pro/automation/xppf.htm JR > While debugging an X10 problem recently I paid some attention to signal
> levels. I have a Monterey Instruments powerline signal analyzer > connected to a power strip that has an appliance module. Under some > conditions, the module will not recognize the X10 command. In practice > the problematic conditions are when I turn on either some fluorescent > lights, or a Sony TV. Both reduce the signal level to about .26-.29 > volts, as displayed by the analyzer. I also checked the noise level > using the analyzer, and it remains low (less than 20mv) all the time. 5~> > It seems to me that a quarter of a volt is plenty of signal for an X10 > device to recognize. In practice, I see reliable operation with a > PowerHouse AM466 and the Appliancelinc 2002SHL. An X10 Pro appliance > module and some Honeywell modules do not recognize the signal. I also > tried sending from a different transmitter (CM11A), lest the frequency > be in error. Though the signal levels were even lower, in the low 100mV > range, the appliancelinc and AM466 still responded. > > What are reasonable signal levels for reliable X10 with the better switches and > modules ? > | |||||||||||||
| Similar Threads | Posted |
| X10 signal levels | July 28, 2005, 2:05 pm |
| CM11 signal output dropped to unusable levels | March 18, 2005, 4:41 pm |
| Reading power levels | December 1, 2006, 3:39 pm |
| X10 signal problems... | October 18, 2005, 10:48 am |
| mystery signal | November 11, 2005, 11:02 am |
| Best Way to Amplify X-10 Signal? | March 1, 2006, 7:13 am |
| X10 to Wireless signal | July 20, 2007, 8:26 pm |
| X10 signal amplitude | September 13, 2008, 4:53 am |
| CVBS video signal | April 4, 2005, 3:08 pm |
| Measuring X10 Signal Strength. | May 25, 2005, 8:53 pm |
| is it possible for x10 signal bridge to fail? | August 6, 2005, 9:32 pm |
| Signal bridge question? | December 21, 2005, 2:11 pm |
| a phantom signal source | December 6, 2007, 8:06 am |
| Splitting a CCTV signal to two monitors | May 4, 2005, 1:16 pm |
| Need to very good booster X10 signal on both phases? | June 28, 2005, 5:46 am |
X10 signal levels
Yahoo!
Windows Live
del.icio.us
digg
Netscape
