General Home Automation X10 continuous bright problem...
Subject Author Date
X10 continuous bright problem... martin.reynolds 05-07-07
Posted by on May 7, 2007, 2:06 am
I've been running a fairly large X10 system for almost 20 years. 60
modules, repeater. I've eliminated the wireless leg over power lines.
It's been generally reliable, with a few soft spots on long runs and
the occasional killer power supply in a PC, printer or game device. No
whole house filter, but my neighbors are 100 - 200 feet away.
So today, it stops working. Total shutdown. A little research turns up
a continuous E9/bright command. My little tester flags it as a strong,
clean signal with noiseless zeros and full strength 1s.
A long search reveals no suspicious devices, so I turn off the
breakers one at a time. Doesn't work. I open all the breakers, and
find that the signal is on at least two separate circuits. I have the
repeater disconnected as well.
Then comes an indiscretion with the tester as I connect it across the
two lin phases, and it ejects black smoke. So I never quite nailed it
as an external influence, but it seems that is what it has to be.
Almost like one of my neighbors is blasting e9/b with a big amp.
Of course, it is gone now. And the whole house filter will arrive this
week.
Anybody ever seen anything like this? It was almost like a deliberate
jamming signal.
Posted by BruceR on May 7, 2007, 5:18 am
You mention that you've eliminated wireless but it sure sounds like a
stuck button on a Palm Pad or other controller. One of my old BSR
Controllers died by doing something similar.
> week.
> jamming signal.
Posted by Dave Houston on May 7, 2007, 7:48 pm
Bruce, I think Martin meant that he uses a BX24-AHT which lets him control
how to handle wireless signals so they don't automatically end up on the
powerline.
Posted by Dave Houston on May 7, 2007, 6:24 am
Martin,
In addition to Bruce's suggestion of a stuck button, there's a fairly common
occurence with X-10 transceivers getting locked into a continuous state (I
dubbed it "endless dim syndrome".) where they send DIM or BRT until
unplugged. There's also a condition usually referred to as "powerline
storms" which usually is associated with the Leviton HCA02-10E
coupler/repeater although the symptoms you see do not seem to match those
usually seen with the coupler.
Are you using any X-10 transceivers or do you use your BX24-AHT? If you are
using the BX24-AHT it will log any received RF as well as any received PLC
codes so it can help isolate whether this signal is originating as RF or
only as PLC, telling us whether to look under couch cushions or look for PLC
gremlins.
>week.
>jamming signal.
Posted by Art Todesco on May 7, 2007, 8:18 am
Dave Houston wrote:
> Martin,
> gremlins.
>> week.
>> jamming signal.
I had a similar problem, my wife spilled
a bit of tea on her nightstand and
it splashed on the manual controller.
It sent out continuous stuff. I finally
found it, unplugged it and all was well.
After a complete drying out, it
worked again perfectly.
Similar ThreadsPosted
X10 continuous bright problem... May 7, 2007, 2:06 am
X10 problem April 11, 2005, 3:10 pm
Here's a New Problem for Me... March 21, 2006, 12:47 pm
odd problem, odd fix September 23, 2006, 8:53 pm
The problem with HA November 6, 2006, 4:27 pm
Problem with CM11 March 11, 2005, 11:13 am
TM751 Problem November 3, 2005, 10:06 pm
HCM06 Problem January 2, 2006, 10:12 am
XP Chkdsk Problem May 4, 2006, 5:47 pm
LM14A problem May 30, 2006, 10:35 am
X10 collision problem June 14, 2006, 6:51 am
x10 switch problem? February 9, 2008, 6:03 pm
Help! Strange X-10 Problem August 28, 2008, 10:19 am
SmartHome SwitchLink Problem March 5, 2005, 2:20 pm
Problem with cheap video cam April 12, 2005, 12:45 pm
