General Home Automation X10 and modified sine wave inverters
Subject Author Date
X10 and modified sine wave inverters DLC 04-09-07
Posted by DLC on April 9, 2007, 4:20 pm
I have a small solar system for my weekend cabin that uses a modified
sine wave inverter.
I want to install a light for the outhouse that is located about 100
feet from the cabin and I would like to be able to control the light
from the cabin and the outhouse. X10 would be adequate if it will work
with the inverter.
Has anyone experience or opinions about this?
Thanks,
DLC
Posted by Dave Houston on April 9, 2007, 4:59 pm
>sine wave inverter.
>with the inverter.
>Thanks,
>DLC
This page suggests it will not work...
http://kbase.x10.com/wiki/Pure_Sine_Wave_Inverters
How do you plan to send the commands? All of the RF transceivers and manual
controllers (e.g. mini/maxi-Controller) send on all three phases so they
will likely fail for the reasons implied on the cited page. I suspect a
transmitter that sends only on one phase might work (if the duration of the
positive square wave is > 1ms) but the only transmitters that send on one
phase are PC interfaces made by Smarthome (e.g. 1132B).
Your best bet would be direct RF control. GE's Smarthome line is inexpensive
but hard to find. 100' line-of-sight is probably OK.
http://www.dimango.com/sa-ge-smart-home.htm
http://davehouston.net
http://tech.groups.yahoo.com/group/roZetta/
roZetta-subscribe@yahoogroups.com
Posted by Dave Houston on April 9, 2007, 5:53 pm
>sine wave inverter.
>with the inverter.
>Thanks,
>DLC
Why not just use a 3-way switch configuration using standard switches?
http://www.selfhelpandmore.com/switchoutlet/3way/index.htm
Posted by DLC on April 10, 2007, 10:07 am
>> sine wave inverter.
>> with the inverter.
>> Thanks,
>> DLC
Thanks for your comments.
I am familiar with 3-way switches and have wired circuits with three
switches.
I was hoping that X-10 could be used so that I would not need to run up
to 150 feet of new wire across a stream and up a hill in order to add
the switch.
Anyway, carrying a lattern seems more appropriate when going to an outhouse.
DLC
Posted by Gerald on April 10, 2007, 4:03 pm
On Tue, 10 Apr 2007 14:07:19 +0000, DLC wrote:
>>> sine wave inverter.
>>> with the inverter.
>>> DLC
> switches.
> the switch.
> DLC
Full on X10 using the PLC part might not work but Dave's suggestion of RF
hints at a solution.
Just pick up an RR501 and a couple of KR22a or KR19A remotes from EBay.
Then modify the RR501 a bit by 1. extending the antenna to make it a true
1/4 wave or 1/2 wave length and 2. (optional) desolder the receptacle and
plug and hard wire it to your incoming power and your light (or skip this
step and plug it into a receptacle in the outhouse and use a plug-in lamp
for the light).
You could probably poke around on Ido's website a bit and figure out how
to disable the PLC xmit/rcv circuitry as well if you're worried that
signals from the RR501 might cause other havoc due to the MSW-inverter.
www.geocities.com/ido_bartana/ <--- as of this message unavailable due to
bandwidth restriction
Here's a google cache of a page from the site dealing with RF range
improvements:
http://72.14.209.104/search?q=cache:Vf5HGYHsNv8J:www.geocities.com/ido_bartana/modifying_remote_control_transce.htm+rr501+bartana&hl=en&ct=clnk&cd=1&gl=us&lr=lang_en
Of course, before modifying anything I would just plug it in and test it
to see how far away you can get and make it work. In an area with little
stray RF you might not need to modify anything.
Gerald
If you need to email me directly use: junkmail sysmatrix
Put the appropriate symbol in there and end it with a fish catcher.
Similar ThreadsPosted
X10 and modified sine wave inverters April 9, 2007, 4:20 pm
Why use X10 over Z-Wave? March 4, 2005, 3:16 am
Z-Wave January 16, 2006, 11:24 am
Q&A About Z-Wave May 5, 2007, 4:03 pm
Z-wave thermostat? March 4, 2005, 4:42 pm
Z-Wave giveaway June 12, 2005, 12:27 am
Z-Wave in the news December 8, 2005, 5:14 pm
Z-WAVE question April 22, 2006, 6:00 pm
a new "Z" wave product June 22, 2006, 5:36 pm
Z-Wave RF range December 13, 2006, 9:20 am
Z-Wave improvement March 13, 2007, 8:27 am
Z-Wave World April 30, 2007, 5:45 pm
Wil I be able to use a Z-Wave controller October 10, 2007, 6:08 am
new z-wave gateway January 13, 2008, 12:22 pm
X10 (new modules) and Z-Wave from Norway February 18, 2005, 5:40 pm
