Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Eric on March 4, 2006, 8:16 am
Please log in for more thread options ActiveHome to schedule them on and off at dusk and dawn. From time to time they come on in a dimmed mode. Any thoughts why? EricD | ||||||||||||||||
Posted by Dave Houston on March 4, 2006, 8:46 am
Please log in for more thread options are designed to come on at the level they were at when turned off. Others can be programmed to come on at a certain level. Still others have no dimming but only on/off. | ||||||||||||||||
Posted by Eric on March 8, 2006, 10:24 am
Please log in for more thread options Dave,
One of the switches is an XPDI3-IW and the other is an XPD3-IW. It's weird the way they are coming on at dusk in a dimmed state. For instance, last night they came on at 30%, but both were the same, they always are. You mentioned that some of the switches are on/off only. Which ones? I've found the part numbering schemes of X10, X10 Pro, and apparently some other lines quite confusing. EricD | ||||||||||||||||
Posted by Dave Houston on March 8, 2006, 12:54 pm
Please log in for more thread options AFAIK those are both only one way and I don't believe they have "memory
dim". However, I do not try to keep up with all of the latest features. Do you have motion or dawn/dusk sensors that turn on the lights? Do you have a phase coupler? It could be that you're experiencing collisions of PLC commands with the result being a Dim command. SmartHome's ToggleLinc PLC switch is On/Off only. http://www.smarthome.com/23895W.HTML They also have a non-dimming ICON switch that can be configured for X-10. http://www.smarthome.com/2876SB.HTML >Dave,
> >One of the switches is an XPDI3-IW and the other is an XPD3-IW. It's >weird the way they are coming on at dusk in a dimmed state. For >instance, last night they came on at 30%, but both were the same, they >always are. > >You mentioned that some of the switches are on/off only. Which ones? > >I've found the part numbering schemes of X10, X10 Pro, and apparently >some other lines quite confusing. > >EricD | ||||||||||||||||
| Similar Threads | Posted |
| X10 Light Switch - comes on dim | March 4, 2006, 8:16 am |
| UPB dimmer switch (must be light almond) | August 6, 2005, 9:34 pm |
| Where can I get a Radio Frequency Light Switch ? | September 22, 2005, 7:31 pm |
| Remote light switch - halogen | January 2, 2007, 11:41 am |
| one switch operated 6 seperate light areas, who makes this? | August 22, 2005, 8:08 am |
| wall mounted light switch with a motion detector | November 25, 2005, 7:36 am |
| Does an automatic shutoff energy saver light switch exist? | January 21, 2007, 6:05 pm |
| Light blinks when (OFF) | December 2, 2005, 6:49 pm |
| IR Phone and light switches | March 27, 2005, 5:18 pm |
| Can a halogen light be dimmed | January 6, 2006, 1:06 pm |
| Wiring a light to a phone | March 13, 2006, 10:08 pm |
| HAI OMNI PRO II Light switches | January 11, 2007, 12:05 pm |
| Does anyone know who is making these light bulbs? | March 23, 2007, 11:48 am |
| Light timer with new DST settings? | May 22, 2007, 12:11 pm |
| CF light bulbs and X10 modules | July 23, 2007, 12:58 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
>EricD
