General Home Automation X10 Controller Oddness?
Subject Author Date
X10 Controller Oddness? David White 04-26-08
Posted by David White on April 26, 2008, 1:46 pm
I am still somewhat new to all this so pardon the newbie questions...
I have 2 manual controllers, a CMA11, a number of modules (light and
applicance), and a couple switches (XPS3 alone and with XPSS or WS14A)
installed in my house. Generally, these work well and as expected.
However, I am trying to debug an occasional issue so I am running my
ActiveHome (v 1.3) connected to my CMA11 and watching the communications
log.
In so doing, I am using my manual controllers - an MC460 and a Radio
Shack mini controller timer - to turn units on and off. When I do this,
I do not see any activity in the communications log for the device which
is supposed to be controlled (B 1-4). Instead, I always see an M13
followed by an M All Units Off with each controller action (both off and
on actions). This seems odd to me:
(a) Why don't I see something in the log for the B1 device I am turning
on and off? The unit does indeed go on/off.
(b) Why am I seeing any activity on the M house code when all the
controllers are set to B?
I must be missing something obvious.
Thanks,
David
Posted by David White on April 26, 2008, 2:57 pm
I have recently installed two XPS3 switches. One - inside my garage -
has a XPSS (WS14A) companion installed and controls my interior garage
lights (both incandescent and fluorescent). The other is stand-alone and
controls the lights on the garage's exterior (incandescent only).
I also have a mini controller (MC460) plugged into an outlet inside the
garage in a location where there are no switches so I can operate both
interior and exterior lights.
Finally, I have my computer connected to a CM11A running ActiveHome
(1.3x). I am using this only for test purposes right now.
So here are the issues:
(a) It seems that the mini controller can ALWAYS turn the interior
lights on (B5) but it has difficulty turning them off sometimes. When
this happens, repeated attempts sometimes work - but not always.
(b) I find the same as (a) when using ActiveHome and the CM11A to
control the interior garage lights (B5).
(c) Neither the mini controller or CM11A seem to have any problems with
the stand-alone XPS3 for the exterior lights (B6). They appear to go
on/off first time, every time.
(d) I have also noted that the interior garage lights sometimes (while I
was in the garage) turn themselves off. This auto-off thing is rare but
it has happened twice that I have noticed (maybe more not noticed).
My first thought is that the interior XPS3 is faulty (or maybe the
companion) since the controller issue seems limited to that switch AND
because that switch does the weird auto-off thing. But the interior
lights ALWAYS seem to respond when either the XPS3 or XPSS is pressed
directly an the controllers always are able to turn them on. So I am not
really sure I can blame them.
That would seem to saddle the problem with the controllers. But I'd
think it very unlikely that BOTH controllers are somehow bad. And they
both work fine on the exterior lights (and other devices). Plus, they do
turn the interior lights ON first time, every time.
Any ideas or suggestions?
Thanks
Posted by BruceR on April 26, 2008, 6:30 pm
Do you have a coupler or repeater installed in the breaker panel or
nearby? Without at least a coupler you cannot expect reliable
operation. Best Bet (by far): buy and install an XTB-IIR from Jeff Volp
http://jeffvolp.home.att.net/xtb_files.htm. It is by far the best X10
problem solver available. Second Choice and not nearly as good: Get a
plug in BoosterLinc from www.smarthome.com that plugs into your 220v
dryer outlet.
> and controls the lights on the garage's exterior (incandescent only).
> the garage in a location where there are no switches so I can operate
> both interior and exterior lights.
> with the stand-alone XPS3 for the exterior lights (B6). They appear
> to go on/off first time, every time.
> (while I was in the garage) turn themselves off. This auto-off thing
> is rare but it has happened twice that I have noticed (maybe more not
> noticed).
> not really sure I can blame them.
> do turn the interior lights ON first time, every time.
> Thanks
Posted by David White on April 26, 2008, 7:27 pm
Thanks for the response Bruce. I had not heard of the XTB units. But in
my old house I had a SmartHome SignalLinc (no booster) in my dryer
outlet. It will not fit my dryer in the new house though (and there is
not enough room behind to fit).
If I understand the SignalLinc and BoosterLinc operation, they both are
attempting to create a better bridge across the two sides of my electric
panel so that signals can pass more easily (the booster adds some form
of signal amplification). Is this correct and true also of Jeff's units?
I have not checked yet to see if the garage interior light circuit and
the circuits having the controllers are on different sides of the
panel. If they turn out to be on the SAME side, what sort of improvement
might I expect from such a unit as Jeff's?
Thanks.
> dryer outlet.
>> noticed).
>> Thanks
Posted by David White on April 26, 2008, 9:15 pm
I have recently installed an XPSS/XPS3 combination for my interior
garage lights. Among the myriad of questions/issues I have been having,
I note the following which is not really that important but still a mystery:
When I turn on the lights via either the XPS3 master switch or the XPSS
slave switch, I see an LED light up on the XPS3. However, although there
seems to be a similar LED in the XPSS, I never see it come on. Other
than this (and the occasional automatic lights turning off) the switches
seem to be working correctly.
Does this indicate that I hosed-up the wiring? Or is that not really an
LED in the XPSS (the manual
it just that the LED in the XPSS is not working?
Thanks
Similar ThreadsPosted
X10 Controller Oddness? April 26, 2008, 1:46 pm
Which controller? July 16, 2008, 9:59 am
Controller Interfaces March 3, 2005, 12:30 am
sensor controller October 8, 2006, 12:08 pm
LED DMX512 controller? December 20, 2006, 4:12 pm
X10 Controller Question April 14, 2007, 4:59 pm
Hybrid controller August 13, 2007, 6:12 am
Wil I be able to use a Z-Wave controller October 10, 2007, 6:08 am
Full Web-Interface Controller? May 25, 2005, 12:26 pm
Landscape Lighting Controller November 8, 2005, 5:09 pm
PowerLinc Controller and X-10 switches December 8, 2005, 6:58 pm
Smarthome Powerlinc Controller February 14, 2006, 10:54 am
Need help with irrigation controller and valve! February 20, 2006, 3:47 pm
2414 INSTEON CONTROLLER May 31, 2006, 1:18 pm
Bigger x-10 maxi controller? December 11, 2006, 9:53 am
