General Home Automation X-10 alternatives for 220V equipment?
Subject Author Date
X-10 alternatives for 220V equipment? Stu Alden 09-06-06
Posted by Stu Alden on September 6, 2006, 8:21 am
I've been using Leviton 220V X-10 receptacles to control swimming pool
equipment and their lifespan is disappointing - they don't seem to
last even two seasons. I realize that there are various hardwired
alternatives that are more weatherproof, but I want to keep using X-10
for flexibility with my HomeSeer setup.
Has anyone been in my situation and found a better alternative? For
example, if I used the X-10 HD245 modules and brought them inside for
the winter, would I have better luck? Thanks.
Posted by on September 7, 2006, 1:42 pm
How about using a standard appliance module to drive a small wall-wart,
which in turn activates a robust relay that would take care of your
current requirement?
Regards,
Anand
Posted by R. Lejeune on September 8, 2006, 8:41 am
Check out the 9100 from Elk Products at
http://www.elkproducts.com/products/elk-9100.htm
The HD245's from X10 have the same internal mechanism as the Leviton
receptacles. I think they wear out from use more than from temperature
extremes.
Posted by none on September 9, 2006, 12:04 am
The Elk 9100 is great, they are serious heavy duty X10
I would also recommend the ACT RB204 (ACT makes the best industrial grade
X10 stuff)
http://www.act-solutions.com/pdfs/PCCSpecs/rb204_spec.pdf
The RB204 has some extra features such as the ability for remote manual
control (simple contact closure) and the relay is user replaceable.
> extremes.
----== Posted via Newsfeeds.Com - Unlimited-Unrestricted-Secure Usenet News==----
http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+
Newsgroups
----= East and West-Coast Server Farms - Total Privacy via Encryption =----
Posted by Stu Alden on September 9, 2006, 11:56 am
Thanks for those suggestions, I will check them out.
says...
> X10 stuff)
> > extremes.
News==----
Newsgroups
Similar ThreadsPosted
X-10 alternatives for 220V equipment? September 6, 2006, 8:21 am
wireless security alternatives.. June 16, 2005, 11:02 pm
Telecommunications Alternatives For The Distributed Workforce (March 2006) April 26, 2006, 8:31 am
need a 220v thermostat intelligent March 2, 2005, 8:55 pm
Powerlinc 1132B in 220V May 1, 2006, 2:59 am
Convert CM15A from 120V to 220V April 7, 2005, 9:28 am
110v to 220V mod on new layout AM486 January 22, 2009, 10:15 am
[Q] Can I use 230V/50Hz X10 Modules to 220V/60Hz country? January 20, 2006, 2:04 am
Need help to buy correct X10 equipment. April 13, 2005, 1:29 pm
Equipment setup March 15, 2006, 6:32 am
My Elk equipment list May 1, 2006, 2:38 am
Heating Equipment - Electric Heaters October 27, 2007, 6:16 am
Why deliberately shorting equipment to blow breakers might be a bad idea . . . January 12, 2007, 1:03 am
Preperations for home automation with existing equipment thru network adjustment questions February 26, 2005, 1:13 pm
Residential Cabling Guide
Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Learn More
