Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Robert Green on May 20, 2007, 8:31 am
Please log in for more thread options switcher capable of taking the typical yellow-red-white RCA type AV connectors? Those are the kind found on VCRs and such and I want to switch them, cascade style via a "pulse" from X-10 controller. I want to be able to remotely switch a DVD player, the front door cam, the doggie cam and the VCR into a NEC AV monitor. I'm using a 4 input autosense box from RatShack that occasionally goes senseless and selects the wrong source and has no provision for a remote. I have two different IR remote switchers that my learning remote has been unable to learn. I could get by with a unit that could "learn" an IR code the way my remote drape control works. Put it in "learn mode" and then press an infrequently used key your TV remote and the controller would cycle each time it saw that single learned command. Cycling through the inputs would be all I would need. The key requirement is that this can't generate the need for another remote or even learning another remote IR command - my learning remote is very much maxed out. I still have two free "devices" CABLE and SAT I don't use in my setup (no cable box, no satellite!) that I could use to control a lot of gear if I could translate those codes quickly into something an IR controlled device like a switchbox, a fan, or even my AC window unit can read I've been looking at the Global Cache units http://www.globalcache.com/products/ir-index.html that appears to be able to easily translate IR codes from one device to another and it sounds like I might be able to hack something together with relays and such, but I probably could do that with a multiple pole 6 or 8 position stepper relay. I'd much rather find the two contact points to short on the Radio Shack or the Emerson or TargMart switchers and connect them to a universal module. I have a whole "bank" of IR codes available on the SAT memory and I'd like to put them to use. The video switcher is one use, and I'd like to make every remote capable of activating a house-wide speaker phone and maybe even arm the alarm. The ability to make the remote independent of the device would be nice. What I don't want is excessive latency. More than a fraction of a second become noticeable. Anything close to a second is unworkable. If it takes too long for a translator to respond, the user begins pressing other keys and pandemonium results. -- Bobby G. | ||||||||||||||||||||||||||||||||||||||||||||||||||||
Posted by Dave Houston on May 20, 2007, 3:29 pm
Please log in for more thread options do. AFAIK it cannot translate codes. You can use an Ocelot as a translator. Here's one designed for translation... http://www.irtrans.de/en/technicalinfo/translator.php | ||||||||||||||||||||||||||||||||||||||||||||||||||||
Posted by Robert Green on May 21, 2007, 7:40 am
Please log in for more thread options > I think you are reading more into the Global Cache description than it can
> do. AFAIK it cannot translate codes. I think you're right. I saw listings for "converters" but it's just for cabling. > You can use an Ocelot as a translator.
To get the Ocelot to learn codes reliably, I followed Guy Lavoie's admonition to use one second long button presses. While that seemed to work in *most* cases, the time lag it induced was not within acceptable limits. What I would want is something that can recognize an IR command and spit out another one as fast as the IR232 can convert Sony IR to serial text messages. What I will likely do is get an RS232 enabled AV switcher and use one of the unused remote devices to send codes to the IR232 to command both the security MUX and the AV switcher. The insidious problem in this approach may be that I don't think that either the SAT or CABLE device memories have any number codes I can enter that will produce SONY IR output codes, the only kind that the IR232 seems to be able to read. I suppose I'll have to try a "code search" to see if wither CAT or CABLE can produce IR signals I can use or to loo > Here's one designed for translation...
> > http://www.irtrans.de/en/technicalinfo/translator.php "Can't find the server at www.irtrans.de." says two different web browsers -- Bobby G. | ||||||||||||||||||||||||||||||||||||||||||||||||||||
Posted by Dave Houston on May 21, 2007, 2:12 pm
>> >> http://www.irtrans.de/en/technicalinfo/translator.php >
>"Can't find the server at www.irtrans.de." says two different web browsers No problem here with FireFox or IE7. It looks like what you want but I could not find prices anywhere on the site. | ||||||||||||||||||||||||||||||||||||||||||||||||||||
Posted by Robert L Bass on May 21, 2007, 3:07 pm
Please log in for more thread options >>> http://www.irtrans.de/en/technicalinfo/translator.php
> It looks like what you want but I could > not find prices anywhere on the site. Ordering is here: http://www.irtrans.de/en/shop/ -- Regards, Robert L Bass =============================>
Bass Home Electronics
941-925-8650 4883 Fallcrest Circle Sarasota · Florida · 34233 http://www.bassburglaralarms.com =============================>
| Similar Threads | Posted |
| X-10 AV switcher | May 20, 2007, 8:31 am |
| Audio Matrix Switcher | July 20, 2006, 9:00 pm |
X-10 AV switcher
Yahoo!
Windows Live
del.icio.us
digg
Netscape
>another...
