Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by JW on March 26, 2006, 12:37 pm
Please log in for more thread options transceiver modules? Thanks | ||||||||||||||||||||||||||||||||||||||||
Posted by Dave Houston on March 26, 2006, 2:44 pm
Please log in for more thread options With two transceivers it depends on which transceivers. Two TM751s are OK except for unit codes 1 & 9 if the transceivers are on opposite phases. | ||||||||||||||||||||||||||||||||||||||||
Posted by JW on March 26, 2006, 9:50 pm
Please log in for more thread options Got it...thanks.
> Two CM11As will coexist without problems.
> > With two transceivers it depends on which transceivers. Two TM751s are OK > except for unit codes 1 & 9 if the transceivers are on opposite phases. > > >>2 CM11s programmed the same in different parts of the house? Or 2
>>transceiver modules? Thanks >> >
Posted by JW on March 27, 2006, 11:27 am
Please log in for more thread options Dave, I recognized the model you mentioned but after looking at my
transceivers, the 751 doesn't have the unit codes, the RR501 does. Did you mean 501, not 751? Thanks, Joe > Two CM11As will coexist without problems.
Posted by Robert Green on March 27, 2006, 12:16 pm
Please log in for more thread options I think he meant that you can't set any units to those two codes when using
dual TM-751's without a danger of collisions. -- Bobby G. > Dave, I recognized the model you mentioned but after looking at my
you
> transceivers, the 751 doesn't have the unit codes, the RR501 does. Did > mean 501, not 751? Thanks, Joe
OK
> > > > With two transceivers it depends on which transceivers. Two TM751s are > > except for unit codes 1 & 9 if the transceivers are on opposite phases.
> >>transceiver modules? Thanks > >> > >
Would This Work?
Yahoo!
Windows Live
del.icio.us
digg
Netscape
