General Home Automation Wiring panel for living area
please rate
this thread
Posted by Dennis on March 30, 2006, 1:40 pm
Are there wiring panels for bringing all the wires involved in a whole
house sound system, as well as the surround speakers in the main
listening area into a nice connection panel in the main living area
where the equipment will be?  At first I was going to run them all into
the utility room into the panels there for the other structured wiring,
but the more I think about it, the more this sounds like the wrong
approach.  There's going to be a lot of wires, from the AV surround
sound receiver, and/or a multi-channel amplifier, etc that will need to
be connected to all those speaker wires hopefully in a neat concealed
panel somehow.
Any ideas/approaches appreciated.
Dennis
Posted by Robert L Bass on March 31, 2006, 12:05 am
Hi Dennis,
I've done a fair number of sound systems over the years.  Here's how I like to
do it.  YMMV.
In or adjacent to the HT room install a thru-wall rack (Middle Atlantic builds
some of the best on the market).  I like to make the rack at least 50 units
(75") high.  A nearby closet is the best location since you can open the door to
access the rear of the rack when you need to work on something.
All speaker cables terminate inside the rack closet.  Amplifiers are normally
installed on shelves inside the closet with only those devices (DVD player,
receiver, etc.) requiring front panel access in the rack itself.
If your room or your wife won't permit a rack, then route your cables to one or
more triple-gang mud rings behind the armoire where your gear will reside.
Install face plates (OnQ, Leviton, and Russound are several good makes which I
sell; Niles is another good brand which I don't sell) with binding posts for
each speaker cable.  Connect the amps to the posts using short runs of cable
with banana plugs (same brand array) on each end.
If you were going to install a multi-zone system such as Russound CAV66 or
Xantech MRC88 you would connect the speakers and remote keypads directly to the
controller.  If you only need speakers and volume controls, say for a 1-zone
system, you can splice multiple speakers together behind the wall and pigtail
them to a single left and right jack.  If you do that, be sure the pigtail cable
and connectors are of sufficient gauge to handle the combined load.  Impendence
matching volume controls will allow you to connect multiple speakers to a single
amp.
For the surround system, wire each speaker to a single jack behind the armoire
or, if you have a rack, directly to the appropriate output of the receiver.  If
you're using a powered subwoofer, don't forget to run a line level ("RCA") cable
from the receiver to the wall behind the sub.
A friend used to build custom speaker cabinets for my installations.  One of our
favorite ways to trick out a job was to install a subwoofer between the floor
joists in the basement beneath a first floor listening room.  If there was a
wooden floor we'd cut an opening for the sound and fit it with a stained oak air
vent designed for floor use.  Below the insert we'd stretch black speaker cloth.
This was usually installed near the front of the room, off to one side of the TV
screen.  I'd power the subwoofer from a pro stage amp in the stack.  If there
wasn't a dedicated subwoofer output on the receiver (they weren't quite
universal back then) I'd also install an active crossover between the pre-amp
and the main.  The effect was terrific -- rich, powerful bass with nothing to
see in the room.
There are a plethora of structured wiring panels on the market, most of which
include optional connections for whole house sound systems.  The problem is they
don't really do anything for your sound system.  It's usually better to connect
source equipment, speakers, etc., directly to the receiver or multi-room
amplifier.  If you want to control the system from various locations throughout
the home, consider one of the multi-zone systems I mentioned above.  I sell
those brands so I'm kind of biased in their favor but they are very good quality
and (I think) fairly priced.
If you only want a single-zone system, you really won't benefit from utilizing
any of the wiring cabinets.
You could run the wires to the utility room but it really won't make things any
better for you.  In audio design there's a saying that the best system is a
"straight wire with gain".  The point is that the less you do to the system
(less connection points, less "treatment" of the sound, etc.) the better the
final result will be.  It's the same reason I disagree with those who insist on
using baluns and CAT5 to bring A/V signals from one place to another unless
there's a great distance between them.
If you'd like to discuss your plans at length, feel free to contact me.  I'm
usually around during the day and most weekend mornings.
Regards,
Robert L Bass
Bass Burglar Alarms
The Online DIY Store
http://www.BassBurglarAlarms.com
Never underestimate the power of very stupid people in large groups.
Posted by Dennis on March 31, 2006, 7:20 pm
Hi Robert,
Thanks for the ideas, they are what I was looking for. I am considering
both the multi-channel amplifier approach, although I don't see a need
for the multiple inputs on them, fed from an AV 5.1/7.1 receiver, or an
A-bus system with the same AV receiver.  Do you know of any A-BUS zone
controls that have more then the 6 watts/channel that I am finding?
It's also not clear from what I have read if I could find an AV
receiver with the A-BUS interface built in, including the IR control of
the source switching without the need to use the stick on IR emitters.
It seems like a natural configuration, but so far I haven't seen one.
Thanks
Dennis
Robert L Bass wrote:
to
cable
single
cable
our
air
cloth.
TV
they
quality
Posted by Robert L Bass on March 31, 2006, 8:25 pm
Russound gives 7.5 Watts / channel.  You'll be surprised though.  That's really
plenty for ancillary listening areas like the bedrooms, kitchen, etc.
In how many rooms do you plan to install audio?  There are more powerful systems
available (at somewhat greater cost) but they don't all cost a fortune.  I
handle Russound, Xantech, Channel Vision, ChannelPlus and several others.
I'm not aware of an A-Bus enabled receiver.  Major A/V builders try to target
the largest possible audience.  If they add A-Bus to a receiver the end user
cost increases (engineering, hardware and licensing) and the target audience
diminishes.  If a significant portion of the population becomes interested in
A-Bus we'll see Sony, Yamaha and the rest jumping on the bandwagon.
It's natural to guys like you and me because we're interested in installing
whole-house audio.  Most people are not.  Unfortunately, HA and multi-room audio
are still a niche market and likely will remain so for the foreseeable future.
Regards,
Robert L Bass
Bass Burglar Alarms
Posted by Dennis on April 1, 2006, 3:28 pm
Hi Robert,
I'll take a look at the Russound options.  I didn't realize they
offered a remote amplifier in the zone volume control.  I thought their
design used the multiple channel central amplifier approach.
Thanks
Dennis
systems
audio
This Thread Bookmark this page:  YahooMyWeb Yahoo!  Google Google  Windows Live Favorites Windows Live  del.icio.us del.icio.us  digg digg  Add to Netscape Netscape
Subject Author Date
Wiring panel for living area Dennis 03-30-06
Related PostsForumDate
New Wireless Setup - best ways to expand area coverage? Wireless Networking 2007-11-23
A-Bus and Futuresmart panel General Home Automation 2005-12-06
relocate existing alarm panel. CCTV, Alarms and other Physical Security 2005-12-28
Wiring a house for Satellite Radio General Home Automation 2005-12-27
Any skilled residential installers in New River, AZ area... CCTV, Alarms and other Physical Security 2012-01-22
EXchanges (was: area code named beer) [telecom] General Telecommunications Forum 2011-09-16
Verizon's DSL or not in my upcoming home area? Digital Subscriber Line 2012-04-16
Alarm Screen Shop in NYC Area?? CCTV, Alarms and other Physical Security 2012-05-08
Dividing up bandwidth on an Internet connection? Wireless Networking 2011-07-30
Fuse Panel Recommendation [telecom] General Telecommunications Forum 2011-09-09
Installation/wiring manual for Menvier TS400 Electronic Security in UK 2011-02-16
Startalk 180 wiring connection Nortel Networks 2011-02-08
Bosch: monitoring panel D7412GV2 using DX4020 and D6600 CCTV, Alarms and other Physical Security 2012-01-26
Security Link - Ademco panel ? CCTV, Alarms and other Physical Security 2012-02-18
Latest PostsForumRSS
Can an intruder remotely reset a Linksys WRT54G v5 router to... Wireless Networking
Bob L. ( Message forwarded) CCTV, Alarms and other Physical Security
Mac to VLAN mapping on Cisco switches Cisco Systems
Sality virus help how to get rid of w32 Sality.a e malware... Networking Firewalls
Verizon in $63 Billion Faceoff With AT&T Over Family Pla... General Telecommunications Forum
Question about SmartHome 1132CU programming General Home Automation
Toronto Free Cisco Seminar CCNA CCNP CCIE & BBQ Cisco Certification
SIP Proxy Server on Windows Vista?‏ Voice-Over-IP
WE ARE BUYING NETWORKING - TELECOM USED AND NEW EQUIPMENT CI... Ethernet LAN
Satellite or cable service for local TV broadcasts? Cable Modems
Modular UPS Telecom Technical
Water Damage & Fire Damage Sterling Heights Michigan Nortel Networks
About the Cat 7 cable LAN and Telecom Cabling
Fire Damage Clean Up & Smoke Damage Restoration Home Automation
VPN Soft Reset? Virtual Private Networks
FA: Joe Kane's VIDEO ESSENTIALS laserdisc Home Theater
Fiber Optics in Access Network_CFP Fiber Optics
Which Forum is best for professionals in the alarm business Electronic Security in UK
SIP SDK 3.6 Video Conferencing
Residential Cabling Guide Home Cabling Guide
Finally, an instantly downloadable book that saves you thousands in home improvement dollars! Enjoy living in 21st century technology-advanced home while increasing its selling value and competitive advantage on the real estate market. Whether your cabling is for home office or high-tech leisure, you can wire your home yourself or learn "wirish" to speak with your cabling contractors in their language!
Order Now for Instant Download
