Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by Randy \"Brick\" MacKenna on December 11, 2007, 2:18 pm
Please log in for more thread options and shut off when I try to dim them with my 20 year old x-10 lamp module and 'mini controller'. Even though the transformer says "dimmable" on it, maybe it's time for an upgrade. The new transformer engineer I talked to today said that his high- quality dimmable transformer will work, as long as I use a high- quality dimmer. The tech at the home automation place said that his high-quality Insteon dimmer will work, as long as I use a high-quality transformer. Here are the two products I'm talking about: http://www.toroid.com/standard_transformers/standard_lamp_transformers/standard_lamp.htm http://www.smarthome.com/2466dw.html Before I spend over $100 on this one circuit, do you think this combination will work? Anyone have any similar experience/success that they can share? I can't switch to 120VAC lighting due to in-situ wiring constraints. Need to stick with low voltage. Thanks, Randy | ||||||||||
| Similar Threads | Posted |
| Will this work for dimming 12V Halogen? | December 11, 2007, 2:18 pm |
| halogen lamp on x10 | May 10, 2005, 1:39 am |
| Halogen Bulbs mr16 | November 19, 2005, 7:14 pm |
| Halogen Bulbs mr16 | November 19, 2005, 7:17 pm |
| Can a halogen light be dimmed | January 6, 2006, 1:06 pm |
| Remote light switch - halogen | January 2, 2007, 11:41 am |
| ToggleLinc problem with dimming from PLC | February 24, 2006, 7:02 pm |
| Lamplinc strange dimming response | February 7, 2005, 8:02 pm |
| X10 PowerLinc 1132CU Dimming Problem | December 27, 2005, 8:08 pm |
| Would This Work? | March 26, 2006, 12:37 pm |
| Making an X-10 lamp module immune to dimming | June 4, 2008, 10:19 am |
| How does Insteon work? | June 4, 2007, 9:44 pm |
| For 1-2 days work, some serious HA progress | July 31, 2006, 12:38 am |
| Will IR Illuminator work with any CCD Camera? | December 30, 2006, 10:28 pm |
| LED bulbs that work with dimmers? | March 13, 2007, 7:30 pm |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
