General Home Automation Why would I want to use thermostats with the M1-G?
Subject Author Date
Why would I want to use thermostats with the M1-G? RayWBo@gmail.com 01-21-08
Posted by RayWBo@gmail.com on January 21, 2008, 8:56 am
Hello there,
Was just thinking and trying to plan out what I need to implement the
ELK M1 in my home. In the area of temperature control, I have a
hydronic warm air system with A/C - 2 air handlers, one which has 2
zone dampers.
In looking at thermostats (HAI models), I then questioned if I even
need them - and might be better suited to simply using temperature
sensors in the place of the 3 themostats. Am I missing something or
does this make sense?
I know that some T-stat models can hook up to the zone damper
(ZD)control as well, but also think I could interface to ZD control
from the M1 panel -or- use the relay interface and control them
without a ZD controller.
In my world of justifying toys and gadets, me thinks if I can save
some money be eliminating 3 fancy communicating thermostats, I can
justify the $1200 (ouch!) touch screen with less sharp pain.
Appreciate any feedback..
Ray
Posted by Lewis Gardner on January 21, 2008, 10:39 am
> zone dampers.
The main reason to use thermostats is as a demarcation and user
interface to the HVAC system.
In your own home this might not be needed. If you are comfortable with
servicing your own HVAC system the demarcation between HVAC and
automation isn't an issue. However if you have problems with the HVAC
system be ready for whatever brain dead tech that comes along to blame
any problems on your automation system and try to sell you a whole new
HVAC system.
Thermostats present a fairly friendly user interface that most people
can understand. You may be able to make a better interface with a
touchscreen (especially for a 3 zone system) but not everyone will look
for temperature controls in a non-thermostat type device. Once again, in
your own home this might not be a problem unless you regularly have
house sitters, guests or others that might need to adjust the temperature.
One other item is that thermostats have a anticipation feature that will
start the unit before a set point to make the temperature more even. You
should be able to code a feature like this.
I have a similar issue in my house. Since it is a older house with 2
floors, a single HVAC unit and no return air from the second floor a
thermostat does not work effectively in the summer. I solved this
problem by using a Homevision to run the AC according to duty cycle
instead of temperature. My control relays run in parallel with the
existing thermostat and I set the duty cycle to 0 minutes per hour when
the HVAC guy comes. I pick up the current HVAC status via debounced LEDs
across the existing thermostat contacts. This way the Homevision knows
when the thermostat last ran the AC and won't short cycle of run the AC
prematurely.
Since I have gone over to a M1 I am now debating myself whether to get
an controllable thermostat (RCS) or migrate the programing over to the M1.
Posted by Bill Kearney on January 21, 2008, 11:02 am
> The main reason to use thermostats is as a demarcation and user interface
> to the HVAC system.
Agreed, it's a lot friendlier to be able to punch some buttons on the wall
in the dark at night when it's REALLY COLD. Did it myself just last
evening.
> This way the Homevision knows when the thermostat last ran the AC and
> won't short cycle of run the AC prematurely.
Indeed, you can't just start/stop HVAC systems. There are all sorts of
potential problems with doing so.
> Since I have gone over to a M1 I am now debating myself whether to get an
I'm likewise mulling over just how to integrate a thermostat into a larger
HA setup.
Posted by RayWBo@gmail.com on January 21, 2008, 8:43 pm
On Jan 21, 3:39=A0pm, Lewis Gardner
> > zone dampers.
> HVAC system.
> house sitters, guests or others that might need to adjust the temperature.=
> prematurely.
> an controllable thermostat (RCS) or migrate the programing over to the M1.=
Great response.. Thanks. I did think of HVAC service, that is pretty
much limited to the boiler but is key as you mention. Was thinking of
some simple override switching, but at that point might as well just
put in the thermostats.
Posted by Robert L Bass on January 22, 2008, 11:59 pm
"Dan Lanciani" wrote:
> Rather than that you might want to have the thermostats tell you
> when someone makes a change (Enerzone/Aprilaire support that) and
> then if the change is unacceptable you can restore the set point in
> 10-15 minutes. This avoids the uncertainty in how long the manual
> change can remain in effect and the associated potential for short
> cycling.
Good point, Dan, but perhaps I wasn't being clear. I mean to send
control signals to the stats, instructing them to return to my
preferred settings -- not to over-ride them. That would avoid
short-cycling, no? Responding to a signal from the stats rather than
polling does make more sense though. Thanks.
Regards,
Robert L Bass
Bass Home Electronics
4883 Fallcrest Circle
Sarasota · Florida · 34233
http://www.bassburglaralarms.com
Sales & Tech Support 941-925-8650
Customer Service 941-232-0791
Fax 941-870-3252
Similar ThreadsPosted
Why would I want to use thermostats with the M1-G? January 21, 2008, 8:56 am
Web-enabled thermostats March 8, 2006, 1:11 pm
Thermostats with interface and remote? September 14, 2006, 4:33 pm
