General Home Automation What to look for
Subject Author Date
What to look for SBH 05-28-08
|--> Re: What to look for Steven Sullivan06-01-08
Posted by SBH on May 28, 2008, 10:14 pm
I'm limited in knowledge of home theater equipment and hoping someone can
help me. Basically, I want to install a 5.1, maybe a 7.1 surround sound
system in my basement along with my TV. Though, I know I can pretty much buy
a Yamaha, Denon, Onkyo, etc. and have a decent system (or maybe not) but
what I'd really like to know is....what do I look for in a good system for a
moderate price? Nothing extravagant but nothing cheap. If you were to
basically tell someone to go shopping for a receiver with a list of what to
look for, what would they be?
Thank you for any help I can receive.
Posted by TBerk on May 29, 2008, 1:10 am
When I was spending my own money I liked Harmon Kardon Dolby
recievers. (During a home remodel the cat pissed through the vents on
top, unbeknownst to me until later.) Despite a good clean sound all
the way up to 'way too loud', they are not indestructible. ;])
Right now I have an RCA unit I bought off the shelf (its in storage)
and am using an old Sony just to get by with.
Each of these brands have pluses and minus; mostly in the user
interface portion actually. Somebody else will have another take on it
but unless you have a particular need (two kinds of hardware that
_must_ work without fail), then you are going to find way too many
choices to choose from.
See if you can spend some time in the high end showrooms and try the
things out with power running through them and see if the ergonomic
part of the equation sits right with you.
One last thing; some setups power the sub channels from the central
unit but I find sending the signal to self powered sub, while a bit to
initially setup the right balance, is a better set up down the road.
ht,
TBerk
Posted by Steven Sullivan on June 1, 2008, 11:45 pm
Nowadays, I'd suggest a receiver with good room correction,
such as the Denons with Audyssey MultEQX . HDMI in/outputs
should be standard by now too.
After that the main decision is what speakers to buy.
They'll make the biggest difference.
-S
Poe's Law: Without a winking smiley or other blatant display of humorous
intent, it is impossible to create a parody of a religious Fundamentalist that
SOMEONE won't mistake for the real thing.
Posted by rdclark on June 2, 2008, 11:23 am
> system in my basement along with my TV. Though, I know I can pretty much b=
uy
> what I'd really like to know is....what do I look for in a good system for=
a
> basically tell someone to go shopping for a receiver with a list of what t=
o
There's a lot of discussion these days of "future-proof" receivers.
It's worth considering. The various faqs and discussions available
here are a good place to start:
http://www.avsforum.com/avs-vb/forumdisplay.php?f=3D90
