Posted by Graven Water on July 1, 2008, 5:11 pm
I want to run a portable dehumidifier with an external dehumidistat
(switch that goes on when the humidity is above a certain level).
And I'd like the furnace fan to go on when the dehumidifier does, to
circulate the air in my house so it'll dehumidify my whole house.
The dehumidifier has to have a manual control to do this, because
the ones with electronic controls forget their settings when power goes
off, or they have a capacitor so they remember the setting a short time.
Am I right that this would be a simple thing to do? Can anyone describe
to me how it could be done? I'd get an electrician to set it up, but I'd
like to get an idea of how it would work.
There are various dehumidistats around. Honeywell makes one that is
wall-mounted and directly connected to the house wiring, also one that
is an interrupt switch and plugs into a wall outlet.
thanks
Laura
| Similar Threads | Posted |
| Want a portable dehumidifier to work with heater fan | July 1, 2008, 5:11 pm |
| Re: Want a portable dehumidifier to work with heater fan | July 1, 2008, 7:02 pm |
| Re: Want a portable dehumidifier to work with heater fan | July 1, 2008, 8:18 pm |
| Re: Want a portable dehumidifier to work with heater fan | July 4, 2008, 1:40 pm |
| Would This Work? | March 26, 2006, 12:37 pm |
| How does Insteon work? | June 4, 2007, 9:44 pm |
| Water heater eating X-10 signal | April 16, 2007, 5:11 pm |
| For 1-2 days work, some serious HA progress | July 31, 2006, 12:38 am |
| Will IR Illuminator work with any CCD Camera? | December 30, 2006, 10:28 pm |
| LED bulbs that work with dimmers? | March 13, 2007, 7:30 pm |
| Will this work for dimming 12V Halogen? | December 11, 2007, 2:18 pm |
| Need help with some sort of wireless thermometer set up at work | February 21, 2006, 8:31 am |
| Will a Terk Leapfrog IR extender work with X10 Powermid? | August 28, 2005, 2:37 pm |
| Is xPL the ideal work-around? Need to access the LPT port from MisterHouse... | October 21, 2005, 12:50 pm |
| Converting An Existing X10 System To Work With CFLs | February 9, 2008, 8:30 pm |
