Bookmark this page:
Yahoo!
Windows Live
del.icio.us
digg
Netscape
Posted by petem on February 3, 2010, 2:31 pm
I've seen on a post or on a web site last year a cable that was disgned for home automation that had in the same cable a utp 4 piar cat 5e cable and a 14-2 cable for power... anyone seen that somewhere ?? trying to find some so I could rewire part of my home.. | |||||||||||||||||||||||||||||||
Posted by Bob F on February 5, 2010, 5:31 pm
Please log in for more thread options petem wrote: I thought it was desirable to keep Cat 5 away from power cables, and only cross at right angles. | |||||||||||||||||||||||||||||||
Posted by petem on February 8, 2010, 10:27 am
>> disgned for home automation that had in the same cable a utp 4 piar >> cat 5e cable and a 14-2 cable for power... >> >> anyone seen that somewhere ?? >> >> trying to find some so I could rewire part of my home.. >
> I thought it was desirable to keep Cat 5 away from power cables, and only > cross at right angles. > Yes it is, but in this situation we are nor using it for ethernet... | |||||||||||||||||||||||||||||||
Posted by Bill Kearney on February 5, 2010, 8:50 pm
> for home automation that had in the same cable a utp 4 piar cat 5e cable > and a 14-2 cable for power... > > anyone seen that somewhere ?? > > trying to find some so I could rewire part of my home.. There have been numerous attempts over the years to supply a 'strucutured cabling' solution. In the end it's cheaper and actually easier to install separate wires. Most of the time where the wires need to run isn't the same place. Power goes to one place, network another, audio, etc. That and the structured cables are far more bulky and more hassle to handle. Translating into increased labor costs. Finally, terminating the cable often required special connectors, adding more to the cost and labor expense. Thus running regular wire, separately, ends up being a better solution. | |||||||||||||||||||||||||||||||
Posted by petem on February 8, 2010, 10:28 am
discussion : StydnXqZXIJDV_HWnZ2dnUVZ_gydnZ2d@speakeasy.net... >> I've seen on a post or on a web site last year a cable that was disgned
>> for home automation that had in the same cable a utp 4 piar cat 5e cable >> and a 14-2 cable for power... >> >> anyone seen that somewhere ?? >> >> trying to find some so I could rewire part of my home.. >
> There have been numerous attempts over the years to supply a 'strucutured > cabling' solution. In the end it's cheaper and actually easier to install > separate wires. Most of the time where the wires need to run isn't the > same place. Power goes to one place, network another, audio, etc. Yup for audion and such having different cable passing as far away as possible from 110 volt is the way to go. But when its time to send signal that control automation module, passing the wiring in one shot can be very usefull.. That and the > structured cables are far more bulky and more hassle to handle.
> Translating into increased labor costs. Finally, terminating the cable > often required special connectors, adding more to the cost and labor > expense. Thus running regular wire, separately, ends up being a better > solution. > | |||||||||||||||||||||||||||||||
| Similar Threads | Posted |
| Utp cable bundle with 14-2 ?? | February 3, 2010, 2:31 pm |
| IR cable: can I use CAT-5? | December 29, 2005, 7:04 pm |
| Re: RCA Cable | January 11, 2009, 12:02 am |
| Expensive cable! | April 20, 2008, 9:50 am |
| best cable for video camera | February 14, 2005, 11:13 am |
| Powerfast Cable Tacker | March 25, 2005, 11:36 am |
| x10 CM12u Serial cable Help | April 8, 2005, 11:33 pm |
| which size of OFC loudspeaker cable should I use? | May 22, 2005, 3:10 pm |
| Network & TV cable question | July 21, 2005, 2:48 am |
| POTS and Ethernet over CAT-5 Cable | August 14, 2005, 3:08 pm |
| Detecting where a coax cable goes to | January 21, 2006, 6:38 pm |
| Cable-pulling Humor | February 13, 2006, 3:53 pm |
| RF Modulator and Cable Modem | October 12, 2006, 12:16 am |
| Wireless Cable Info | November 4, 2006, 12:29 pm |
| Use of FTP cable in home network | September 29, 2007, 5:24 am |
Yahoo!
Windows Live
del.icio.us
digg
Netscape
