General Home Automation UPB dimmer switch (must be light almond)
Subject Author Date
UPB dimmer switch (must be light almond) Kevin 08-06-05
Posted by Kevin on August 6, 2005, 9:34 pm
I'm looking specifically for light almond colored UPB dimmer switches but
not having any luck. Anyone know if they exist?
Thanks
Posted by Mark Thomas on August 8, 2005, 10:38 am
> Thanks
Do you mean "light almond" as in "almond, the color that's lighter than
ivory" or as in "a shade of almond that is lighter than other almond
switches"?
If it's the former, you can get almond UPB switches here:
http://www.digitalavnew.com/UPBprod23.htm
The pricier PCS brand are available at HomeControls and Worthington
too.
- Mark.
Posted by Kevin on August 8, 2005, 10:15 pm
Unfortunately I mean the latter ("light almond" a shade lighter than
almond).
Thanks anyways.
>> Thanks
> switches"?
> too.
> - Mark.
Posted by wkearney99 on August 8, 2005, 11:28 am
news:taSdnZ2dnZ2BMfPNnZ2dnZL6aN-dnZ2dRVn-
The only switches that have that fine a range of color selection are those
from Lutron's RadioRA line. You can get danged near any color.
Tragically, however, they don't eff'ing sell replacement fascia. So when,
and DO mean WHEN, you or your painter mucks one up you're faced with total
replacement.
Otherwise they're absolutely rock-solid in their automation functions. Not
cheap, but plenty of colors and THEY WORK. After more than a decade of
futzing around with X-10 I have to say I'm delighted with how well these
work.
-Bill Kearney
Posted by Charlie Derk on August 12, 2005, 10:32 pm
Bill -
Lutron announced at CES I believe, a new style RadioRA dimmer that is
field-colorizable.
Charlie
> replacement.
> work.
> -Bill Kearney
Similar ThreadsPosted
UPB dimmer switch (must be light almond) August 6, 2005, 9:34 pm
$20 Insteon dimmer switch December 24, 2005, 8:56 am
IR dimmer switch to go with Harmony 659 July 8, 2006, 12:51 am
Two-way, two-wire wall dimmer switch? February 16, 2006, 6:12 pm
Leviton "Air Gap Switch" on Dimmer Controls July 2, 2008, 12:41 pm
Zwave In-Wall Switch/Dimmer with RF Remote Control Capabilities January 7, 2007, 9:42 pm
X10 Light Switch - comes on dim March 4, 2006, 8:16 am
Where can I get a Radio Frequency Light Switch ? September 22, 2005, 7:31 pm
Remote light switch - halogen January 2, 2007, 11:41 am
one switch operated 6 seperate light areas, who makes this? August 22, 2005, 8:08 am
wall mounted light switch with a motion detector November 25, 2005, 7:36 am
Does an automatic shutoff energy saver light switch exist? January 21, 2007, 6:05 pm
Programmable dimmer May 25, 2005, 9:56 am
ILS 2000 dimmer October 18, 2005, 3:53 pm
Low voltage dimmer June 6, 2007, 12:57 am
