General Home Automation Switch Conversion???
Subject Author Date
Switch Conversion??? ABLE_1 06-22-08
Posted by Jeff Volp on June 22, 2008, 10:37 am
What you may have is an old GE low-voltage installation. The place where I
worked back East had that type of system. The rockers were horizontal -
maybe 5/8" by 1 1/4" if I remember right. There was no local click or snap
when the switch was pressed, but I could hear a click from the relay in the
ceiling. As I recall, that system was discontinued years ago, and it has
become a retrofit nightmare as the components wear out.
If that truly is a low-voltage system, then the wiring is apt to be
low-voltage too. Somehow you will have to deal with that. I am not aware
of any home automation equipment that will work with that kind of switch.
Jeff
> I am getting a little concerned that they may be Low Voltage but I am
> hoping not. I may have to do some more on site investigation to confirm.
>> ABLE_1 wrote:
>>> I have a potential customer that has a house built in the 50's. The
>>> electrical switches are an odd style in that the plates sit horizontal
>>> and the toggles are more like rockers about the size of your thumb.
>>> First I am looking for a name, style, or model on this type of switch.
>>> I have googled and ebayed but can't seem to find a picture for a
>>> reference.
>>> Second I would like some hints as to how to install some automation to
>>> control lights and such with this type of switch??
Posted by ABLE_1 on June 22, 2008, 10:41 am
Sound about right. I must do more investigation. Thanks for the GE point.
That may be helpful.
Les
> I worked back East had that type of system. The rockers were horizontal -
> snap when the switch was pressed, but I could hear a click from the relay
> in the ceiling. As I recall, that system was discontinued years ago, and
> it has become a retrofit nightmare as the components wear out.
> Jeff
>>>> reference.
Posted by Frank Olson on June 22, 2008, 10:44 am
> Jeff
I'm postive that if anyone could "cobble" something together to make
*any* lighting system work with X-10, it would be someone in *this*
group. :-)
Posted by marcus hall on June 25, 2008, 2:29 pm
Actually, the GE RR7/RR9 systems are still produced, sold, and installed.
Parts are readily available, and there is also at least one competitor,
touchplate, that makes similar systems.
I think that GE sells an automation interface, but it's a bit pricy for
what you get.
I know that I have seen regular 120V switches that are mounted across
a standard single-box frame. There are one, two, or three switches in
a single gang. These switches would toggle and physically stay one
way or the other. Low-volage switches would be more like a pair of
push-buttons switches. Even if it is built as a toggle switch, when
released it would go back to the center position (neither side being
down).
marcus hall
marcus@tuells.org
Posted by dlh on June 22, 2008, 2:13 pm
> reference.
> Any help would be appreciated.
> TIA
> Les
Look at TouchPlate, LiteTouch, Centralite, Vantage, etc. There are links
to each on this page.
http://davehouston.org/hardwire.htm
If it is GE low voltage system, there are companies that make parts.
http://www.alltestequipment.com/cgi-bin/pdc/viewprod.cgi?
pid=559&tid=1&type=elec
http://www.dale-electric.com/gereplace
TouchPlate did supply parts for GE systems.
http://www.inspect-ny.com/electric/Low_Voltage_Wiring.htm
Good luck.
Similar ThreadsPosted
Switch Conversion??? June 22, 2008, 7:47 am
240 to 120 Conversion ? March 23, 2005, 5:07 pm
What switch is this August 13, 2008, 9:29 am
Modules switch on every second April 12, 2005, 2:31 pm
In Wall Switch August 26, 2005, 5:52 pm
gate switch December 10, 2005, 10:59 pm
Wall switch with 0%-10%-100% only? January 2, 2006, 11:03 pm
OFF AIR DISTRIBUTION SWITCH January 14, 2006, 5:36 pm
OFF AIR DISTRIBUTION SWITCH January 14, 2006, 5:39 pm
X10 Light Switch - comes on dim March 4, 2006, 8:16 am
How to control the switch using RS-232 April 24, 2006, 4:53 am
x10 switch problem? February 9, 2008, 6:03 pm
X-10 Switch Question April 14, 2008, 10:11 pm
X10 switch control logic February 16, 2005, 11:37 am
Relay switch recommendations April 7, 2005, 11:46 am
