General Home Automation Surveillance camera wiring
Subject Author Date
Surveillance camera wiring betty 11-03-07
Posted by betty on November 3, 2007, 2:43 pm
My intent was to set up a surveillance camera and put it on one of my
cable channels to view it. I know I need to get some sort of
modulator or even get it built in like the ones Net Media offers.
I have some questions though about the video signal. A camera such as
the Sanyo vcc-4794 has a BNC connector for the video output. I was
planning to connect this to a coax cable to bring it from my garage to
my house. Is this signal from the camera the same as the video
component of RCA cables?
Is a coax cable the best choice or should I just run a single wire
equivalent to the RCA video wire? Many of the modulators take in RCA
and put them on coax but I just want to make sure I buy the right
stuff.
Any information would be great.
Posted by Frank Olson on November 3, 2007, 4:04 pm
> stuff.
The output on a BNC can be converted to an RCA with no problem (there
are adapters you can buy that work well (with very little in the way of
signal loss). It's best to buy a good quality Coax for the run from the
camera to where-ever it is you're going to hook it up to. RG-6 would
work well (and is readily available). RG-59U is also a good choice but
more expensive. Good luck!
Posted by Robert L Bass on November 3, 2007, 6:30 pm
On Nov 3, 5:04 pm, Frank Olson
> > stuff.
Huh? RG6 is almost invariably more costly than RG59. Professional
installers have been using RG59 for CCTV systems for years. If you
were using high definition (HDTV) cameras you'd need to use RG6,
preferably quad shielded. However, it is highly unlikely you'll find a
need for HD in a typical surveillance project.
Regards,
Robert L Bass
Bass Home Electronics
www.BassBurglarAlarms.com
Posted by Dan Lanciani on November 3, 2007, 6:45 pm
betty111111@gmail.com (betty) writes:
Yes.
| stuff.
Yes, coax is suitable for both baseband video and RF applications. Any
good "RCA video wire" *is* coax. I terminate all RG59 and RG6 cable with
F connectors and then use suitable adapters (usually F to RCA or F to BNC)
at the camera and equipment ends. This makes it easy to change equipment
(so-called "professional" is usually BNC while "consumer" is RCA) and also
means I need remember only one crimping procedure (which also covers RF
applications). :) Note that you can often get bags of adapters on eBay
for the cost of one or two at Radio Shack, but watch the shipping charges.
                                Dan Lanciani
                                ddl@danlan.*com
Posted by betty on November 5, 2007, 4:29 pm
At some point I have to put the signal through an RF modulator to
transfer the camera video onto a cable channel.
Should the modulation happen near the camera (ie. garage) or in my
house? In other words, it is better to have the signal travel as the
video component or as an RF signal?
Similar ThreadsPosted
Surveillance camera wiring November 3, 2007, 2:43 pm
Home surveillance help July 13, 2005, 5:19 pm
Surveillance Cameras January 26, 2007, 7:38 pm
Home video surveillance May 19, 2005, 12:29 pm
IP-based surveillance (indoor) June 2, 2005, 1:05 am
Video Surveillance Software? October 6, 2005, 12:30 am
What is the best surveillance software for 4 ip cameras? January 23, 2007, 12:01 am
Wireless surveillance system August 4, 2007, 12:19 pm
video surveillance dvr systems October 23, 2007, 3:44 pm
Video Surveillance Company for Sale January 9, 2006, 8:00 pm
Time-lapse/surveillance software October 3, 2008, 5:37 am
Teknovation lands Multi-million Video Surveillance Contract March 20, 2005, 10:33 am
X10 Camera question February 9, 2005, 4:58 pm
Best IP camera for home use ? June 7, 2005, 8:33 pm
How to Setup a Camera 120 ft Away? August 6, 2005, 1:23 am
